anyone drawing there cool air from the cowl vents? If so, any do's or donts?
how about sum pics? thanks for ANY input..
68/stocksusp/firebird/461/allpontiac/1.56/60ft/1/8/7.10@96mph |
I can think of about ten do's.
Zero dont's. |
Are you talking about modifying the firewall and using the stock vents or a cowl induction hood?
or bring it in from the grill im trying to stay away from the scoop on the hood deal. thanks for the reply
Yardbird, in about 1966 a friend, who built hot air heating systems, made a hat, like you described, for my dual quad 389 that was ducted from the heater inlet housing in my 63 LeMans. With no other changes, I went from a 12.14 to 11.71.
Bill 64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs. [email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
i realy thought more people would be doing this if it was that big of a plus i guess as long as your not restricting the flow all should be good
Jim Hand has been doing it for years. Air cleaner to firewall cowl duct. His is homemade by adding a second hose duct to a stock aircleaner and two hoses to the holes in firewall. I just read an article on a restored 63 Z-11. Air cleaner to cowl from the factory. RamAir something or other company has been selling air cleaners for years that have two 4" duct openings to go forwards or backwards. Not sure if an air cleaner element goes in it or its just a huge carb hat. The difference in ambient air and underhood air can be well over a hundred degrees.
Fab'd a semi enclosed air cleaner to cowl panel and TA shaker scoop(attached to hood) on my 68 FB.
Lower pan and sides extend to opening in cowl. No top, but with weatherstripping, it should seal 95% to cowl and hood. The windshield is out(stripping/patching/repainting), so i dont know how effective it is yet. Will have pic's as soon as i get someone over to fix home computer
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
Hey Everybody, I just have to ask - Will NHRA allow you to run such a thing in the ET Brackets? Thanks Again, CraigG.
Any pics yet?
im still workin on this ideal,,
i know sumone out there has pics!!?? pleezzz??
Within this article. Double click the photos for larger size.
http://www.carcraft.com/featuredvehi..._lemans_wagon/ |
