I would like to start this thread and make it a 'sticky' so others can see what different combinations people are having success with. This will be a very useful archive to use for future reference for all PY members, your post won't disappear from the top of this page.
'Traditional' 1955 - 1981 Pontiac engines only please. Aftermarket blocks, heads and cranks that fit the 'original' Pontiac V8 engines are also part of it, they're definitely still all 'trad' Pontiac pieces. The '66 -'69 Pontiac OHC-6 engines are welcome. No LSX, Chevy, Olds, or any other engines. Please post the component combo of your running street engines only, not the combo you're now building or might build someday. The more details, the better. If you've run your car down at your local dragstrip, we sure want to know what E.T. and MPH it ran. Let us know what kind of car the engine resides in and the car's weight if you know. We need to know what transmission, torque converter (if auto), rear end gears and rear tire size you're running if posting dragstrip results. If you've had it on an engine or chassis dyno, please share the HP/TQ numbers or your dyno sheets. Everyone has a different idea of what constitutes a 'true' street engine. Some folks drive their near-stock street engines hundreds of miles on road trips, other just rumble around town with their really wild street engine in a thinly-disguised race car. As long as you use your car on the street on a regular or semi-regular basis, we want to know all about the engine. Post a picture of your engine if you can or of the car your engine lives in (one only full-size pic please), we would all like to see what your Pontiac engine looks like. Do not post pictures that are so large that we have to scroll back and forth to read the thread. Please reduce the size of your pictures, if you don't know how please ask in the 'Test & Tune' forum. Post all the thumbnails you want, you can download up to 5 of them in the current format. The whole point is to keep this thread easy to read. I will delete pictures that are too large (no larger than 640 X 480 pixels). Please help keep this thread 'clean', nothing other than your engine combo can be posted in this thread. If you have questions, please send a Private Message to the engine's owner or start a new thread asking your question. You can link to the individual post you are referring to by clicking on the post # in the upper right hand corner of the post, then copy and paste the link that appears to put in your new thread. This is a reference thread only, not a Q & A thread. It loses usefulness with a bunch of questions and answers mixed in. I will delete any posts by members who are not presenting their engine combo. Please do your best to put up a quality post on your combo, spend a little time so others can benefit. Step up and post your street engine combo, Pontiac fans!
Great site idea B-Man.
http://www.pontiacstreetperformance....455jh2006.html I added this link as it pops you into more details than you could ever hope to see in one place. Plus, I am a terrible typer and this way, you can see it all correctly organized. ![]() ![]() Every single "secret" is revealed in grand detail here too. ![]() http://www.pontiacstreetperformance....455jh2006.html I will also add a link to the car in action. No dyno numbers but some real strip numbers to share. http://www.youtube.com/watch?v=8GHYxPqePv8 And here is one so those interested can see how truly quiet this street car is when it runs mid 11's. If you listen, you can tell by the low rpm it is geared rather mildy (3.31) And, since both 3" tailpipes come out this side, you can really tell how quiet Goerlich's large case 3" XLERATORS are, even on an engine this powerful. http://www.youtube.com/watch?v=Ta6kP3itZx8 Tom
Tom Hand Last edited by Tom Hand; 05-10-2007 at 10:16 PM. |
1973 Trans Am all stock, power windows, AC
3820 lbs. curb weight 455 stock bore, stroke, rods, pistons,etc 7M5 heads, stock valves, 1.65 stock type rockers stock intake original QJet, with modified secondary rods TH400 stock except I modified govenor stock converter 3.08 posi 10 bolt rear, stock Rally II wheels stock 275-60-15 tires on rear 255-60-15 tires on front best 1/4 mile: 13.99 @ 102 MPH at Norwalk best 1/8th mile: 9.00 @ 79 MPH at CCD
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates Last edited by johnta1; 05-10-2007 at 11:16 PM. |
My low-compression 455 street engine, built with 99% stock parts. It would be hard to build a milder (or cheaper) 455.
1973 455 block bored +.030 for 462 cubes, no decking or line bore/hone. TRW forged pistons, matched to the weight of the original factory pistons/pins. Pistons at zero-deck (zero to -.005"), same as factory pistons. Stock un-rebuilt cast rods with original bolts, std./std. stock 455 cast crank, no balancing other than the factory balance job.1971 #66 455 114cc heads (no porting/port matching or milling) converted to 7/16" straight screw-in studs, 8.2:1 compression. Crane 068 'Blueprint' cam, installed straight-up with Cloyes Tru-Roller timing chain set. Stock stamped steel RAIV 1.65 rockers, polylock nuts, stock 5/16" pushrods, Edelbrock 5758 springs, stock retainers/keepers. Melling M54DS oil pump (pickup retained with 10-32 bolt tapped and loctited), HO Racing hardened oil pump driveshaft, 1973 baffled oil pan with HO Racing trap-door mod for retaining oil pressure on hard right turns. Oil filter adapter bypass plugged with 3/8 pipe plug. 1966 Tri-Power, stock including jetting with K&N filters. 1967 HO repro exhaust manifolds, full 2-1/2" exhaust with 17749 20" long Walker Dynomax Super Turbo mufflers. Stock points distributor/stock coil ignition, HO Racing curve kit TH400 trans/13" Continental converter, original 2.56 geared 8.2" 10-bolt open rear, 235/45-17 (25.3" tall) street tires. 1964 Tempest weighing in at 3780# w/o driver. Dragstrip results: 13.899 @ 101.85 MPH going through the traps in 2nd gear, shifting at 5000 RPM. This was the only run I could get in at the crowded track that day, but I was glad to come home with a 13-second timeslip. Couldn't launch it hard, otherwise no traction. Pitiful 2.3-second 60' times, the Tempest was built for cornering and highway flying (saw 140 MPH once). An honest 335 HP at the flywheel, runs on 87 octane.
| The Following User Says Thank You to b-man For This Useful Post: | ||
1971 Ventura II curb weight 3060# plus my 240# = race weight 3300#
1971 400 bored 0.030 (one sleeve required) TRW L3035F "Cast" flattops w/ 8 valve reliefs Hasting Moly faced rings 6.625 stock rods w/Milodon bolts 3.75 stock "71" crank turned .010/.020 Correction, actually 0.020 rods and 0.010 mains Melling 60# oil pump UPGRADE: Summit True Roller set (Dyna gear all steel 3 piece timing set) Professional products street/strip dampner Scat SFI flexplate stock OEM balance, wasn't in the budget. lolUPGRADE: Crower #60311 Net after lash 0.022/0.024 .532/.541 @0.050 .247/.252 lsa 112 Crower metered solid lifters Crower #60916 cam, Crower hyd lifters, Crower #68404 Dual springs, and Crane Energizer 1.65 rockers. w/BBC 7/16 studs 1968 #16 heads 2.11/1.77 milled 0.035 on the deck and intake side to get a true 72 cc chamber. Gasket matched to #1233's. I home ported my heads a little conservative, K&M machine estimated 240+ cfm INT and 185-190 EXH flow.(No flow sheets) Final compression came out at 9.44-1 UPDATE: Comp actually 9.70-1 Holley #4779-4 750 DP w/milled choke tower. Jets 72/80, towers .031/.035, PV front 6.5hg Rear plugged. Tuned the squirters with what ever cams it came with. (They are faded no way to tell) "REGULAR" Performer intake w/separated water crossover gasket matched and blended to the #1233's. I use a cheap TransDapt adapter for the Holley carb which helps smooth the transition. UPDATE: Hand filed casting flash in venturi's, contoured and radius airhorn, polished the venturi's and airhorn, knife edged the remaining seperation between the primaries/secondaries, rear jet extensions, BG slotted float, jetted 76/85, started using the 4 corner idle, 3.5 Hg PV,and changed to a port matched Torker II intake HEI curved for 20 degrees mechanical and 16 Initial NO vacuum can. 36 total all in by 1800 rpm. 990 module, stock OEM coil, and Taylor 8.2mm ThunderVolt wires. UPDATE: locked mechanical @20 tune engine at 36 total 13 yr old Summit 4 tube headers. w/leaks lol 2.5" dual exhaust NO crossover w/Dynomax Super Turbo's. Dumps just PAST the rearend. UPDATE: swapped the Summit headers for a set of Hooker Competition w/ceramic coating, 2007 Plastic flex-fan and large two core aluminum radiator w/home made shroud. TH350 Trans-go shift kit, Hughes GM25 converter, and either 3.70 or current 4.30 3rd members in a 9" rearend. W/ Comp Engineering bars and 50/50 oil filled shocks rear. Old rusty unknown shocks on the front. BFG 275/60/15 DR's 28" tall UPDATE: Swapped out the Hughes converter to the "Redneck" 9.5", it footbrakes to 3200-3300 and flashes to 3600-3800, currently running the 4.30 spool setup Car ran a best of 12.991 @106.54 mph w/1.940 60' w/3.70 gear Car ran it's best 12.60 @104.78 mph w/ 1.864 60' w/4.30 gear Car ran it's best 12.59 @107.29 mph w/ 1.869 60' w/4.30 gear The only change I made from previous best was removed the filter element in my Fram canister fuel filter which validated a fuel volume delivery issue. Dropping .01 and getting + 2.51 MPH was great, especially for free! Once I get a little more converter (Redneck "Tight" 3500) and upgrade my fuel system (-8 from cell to regulator) it should run low 12's! I need a better 60'!!! JD P.S. ??? Unknown yet how the new combo will respond! Hopefully weather permitting I'll know by the middle of Nov.!
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
73 400 .040 over
stock innerds...yep summit 2802 cam 4X heads mildly ported 1.5 roller rockers dougs headers Vortech YSI trim super charger (7lbs boost) Holley 900 cfm TBI fuel injection water/alcohol injection edlebrock performer intake Mallory mag distributor Tremec 6 speed hydraulic throw out bearing hays steel flywheel center force dual friction 12 bolt posi 3.90's
Vic in SoCal. Follow me on Instagram- Cloud9orbust 66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi. ![]() My T56 Install My Turbo Build My Vortech Supercharger Build Hyd Throw out bearing Misc Build Pics May the Karma Gods meet you half way.... |
Combo #1 - 406
'72 400 block +.030, dished forged pistons, stock rods with ARP bolts, balanced. '70 # 13 heads with a 5-angle valve job followed by bowl blending and gasket matching. Stock rocker arms. CR 9.25:1 Comp XE274 cam, Performer intake, Buick 800 Q-jet, HEI distributor, HO Racing Tri-Y headers, Flowmaster 2.5" exhaust, Dr. Gas X-pipe. Engine inhaled through factory Ram Air setup in my 3840 lb race weight '72 Formula with 3.23 rear gears, TH400 with Coan pro-street 3000 stall converter. Best ET of 13.60 @ 102 with a lousy 2.0 60' on street tires. Typical ETs of 13.70-13.80 @ 101 Combo #2 - 440 ci '70 455 block, +.035", '69 428 crank, Eagle rods, Ross dished pistons. '67 #061 heads ported by Dave Bisschop @ SD Performance to 273 cfm intake/200 exhaust. Harland Sharp 1.72 ratio rockers. CR 9.6:1. Old Crane solid roller cam with specs similar to RAIV cam - 232/244 @ .050", 113 LSA, 109 ICL, .335" lobe lift (These are very mild specs for a solid roller!) Crower lifters. All other components same as combo 1. Chassis dyno showed 344 horsepower (can't remember torque), so close to 425 at the flywheel. Best ET of 12.66 @ 108 with a 1.66 60' on street tires with two main bearings showing copper (engine tore down next day when oil filter analysis showed problems). Typical ETs of 12.70-ish @ 106 with 1.80 60'.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
78 trans am, combo is '73 455 bored .30 over. out of the box 85cc KRE aluminum heads(flow 232 at.450). trw forged pistons, stock balanced crank, forged scat rods, ultradyne 230/238 cam with a 112 LS and .541 lift. harland sharp 1.65 roller rockers, performer rpm intake, 850 double pump holley(modified by shaker 455), braided -8AN line from tank to Robmc mechanical fuel pump, -6AN line to carb, 2200 stall with a bowtie stage 3 200r4 overdrive tranny. rear is 3:42. tri-y headers into 2 1/2" flowmaster crossflow muffler. on the chassis dyno, my best #`s were 342hp and 385tq. timing was 34 total. drove 3 hours to the track and 3 hours back. best run was 12.9 @108 spinning through 1st gear and part of second. 60 ft was 2.32. weight is around 3900lbs. street tires are 26" tall. 16" of vac at idle.
71 Ventura
Mini Tubbed Chebby 12 bolt 4.11 295 BFG DR T400 Redneck 3000 428, 4 bolt + .035 455 crank line bored and balanced H- beam rods SRP pistons Comp XE284, straight up RPM Intake 96 d-ports flow 220 cfm 750 Holley ( made same HP as BG 850 on dyno) 1" spacer 443 hp at 5000 532 tque at 3500 3680 race weight - 11.98 @ 109, 1.710 60 ft ( no carb sapcer - won't fit) Changes for this year: 3.73's, caltracs, springs moved in more, M/T 295 DR John |
65 GTO
M-20 transmission. 3.55 10 bolt posi. 389 CI. .030 over. #76 heads, modified so unleaded fuel may be used. Stock crank, rods, pistons. Crane "Powermax" single pattern cam. .454 lift, 290 duration, 110 LSA. 65 tri-power unit. .065 jets in center carb. .070 jets in end carbs. Ram air pan, K & N filters. 60 PSI oil pump. Stock distributor re-curved and converted to electronic, 5 years ago, by Milt Schornack. 12 initial, 34 total. All in by 2400. Still using vacuum can. Engine runs well, without detonation, on 92 or 93 octane fuel. |
1970 Trans Am
462 cid / pump gas TH400 3.73 10-second street car Full details here: http://www.pontiacstreetperformance....455sc2003.html (awaiting new 505 cid to be installed) |
In my 76 TA
76 WX block 40 over 455 CAT rods Stock crank shaft Falt top pistons (9.65:1 calculated) 75 6x-8's reworked by Jim Lehart (bigger valves, 95cc's) Nunzi's RA IV #2042 cam Comp roller tip 1.5 rockers 70 Cast iron intake Stock 76 Q Jet rworked by Cliff 76 Dist recurved by Rocky 30yo Hooker SC (Ceramic coated by Foxfire Coatings) Pypes 2.5" w/ X over (Ceramic coated by FoxfireCoatings) Muncie M22 (2:52? first gear)redone by Hoss' Gear Shop Stock 3:23's out back 16 X 8 Wheel Vintiques R II's Dunlop SP Sport 8000 255/50/16 Koni Classic shocks all the way around I've got 5000 miles on the motor. No problems in traffic or on the open road. Great street manners. It'll sit and idle (lope) all day long. Sweet music to the ear. Mark
70 Bonneville 455, survivor (Third Owner) Last edited by Mark C.; 05-11-2007 at 11:32 PM. |
1966 GTO Post Coupe
389 + .040 over 093 heads TRW rods and pistons Roller rockers RAM IV Cam Edelbrock Performer Intake Stock distributor re-curved and converted to Pertronics 4bbl Quadrajet Hedman Headers (ceramic-coated) Ram Air pan, K&N filters TH350 tranny w/ shift kit 3.55 10-bolt Posi (8.2" Auburn carrier and Eaton gears) 2.5" custom-bent welded dual exhaust with Dynomax SuperTurbo mufflers 92\93 octane fuel 15x7 (front) & 15x8 (rear) Wheel Vintiques' Rally II's with 235/60R15 BFG's Last edited by winbub; 05-11-2007 at 01:14 PM. |
'66 GTO Convertible
'74 455 .030 over Stock Nodular crank Scat H beam rods Ross forged pistons KRE 290 D ports 85CC 10.5:1 CR Dougs headers 3" Pypes X system with dumps, Race Flo mufflers Crane 289621 HR (222/230 .509/.528) HS 1.65 roller rockers Aluminum '66 tripower intake, ported by CVM. Jet "Circle Track" center carb, ported end carbs Dave's small body HEI with MSD 6AL. 16 initial, 20 mechanical and 8 vac. Tremec TKO600 Moser 12 bolt 4:10 It idles smoothly at 800 rpm, tons of torque from off idle to rev limiter (6200) It pulls 20" of vac at idle with the vacuum advance connected, and 16 without. |
1969 GTO with it's original 400
.030 over L2262 TRW pistons stock rods and crank Comp Cams hyd roller cam. Straight up 220/224 with .513/528 lift. Comp hyd roller lifters Harland Sharp 1.50 rockers 995 springs moly pushrods #48 heads with 2.11/1.77 stainless valves Dude's level #1 port work. (mild clean up) Rollmaster timing set Qjet that I built using a 1979 Olds core with Cliff's and Doug Roes books. No choke 1" 4 hole carb spacer Factory intake with the exhaust and crossover removed. Water crossover separated Intake ports gasket matched and aligned to the head ports Ram Air III exhaust manifolds 2.5" mandrel bent pipes with long case Dynomax Super Turbos Dave Ray HEI conversion 11" PTC torque converter Turbo 400 3.55 gear Auburn Pro Series posi Recently ran 13.55 @ 101.5 on 255/60-15 Radial T/A's. The engine began to "nose over" part way through 2nd gear due to lack of fuel. With traction and fuel?????? Idles with just a slight bump and about 15-15.5" vacuum. Engine had a different carb in the picture............
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
66 GTO
389 + .030, 093 heads 1.92I, 1.66E (1st time port job for me), chambers 70cc, cr 10.7-1, stock intake, 750 Edlebrock, 1.65 HS rr, Isky 262 cam 108lca,208 dur @ .050 single pattern, zero deck, stock rods, forged 389 pistons, small body HEI, max mech advance 27 deg, BlackJack 3 tube headers, th350, 2k stall, 3.55 gears, G60x15 MT Indy SS,3900# w/driver. 3" exhaust 2 1/2 muffs. Shift @ 5200rpms,Best 13.60, 13.70's all day long, best mph 99.07. Chassis dyno'd @ 260 rwhp, 350 tq. Same setup with #46 heads 1.96 I, 1.66 E (2nd port job by me), chambers 79cc, cr 9.7-1, RPM300 Isky solid 228@ .050 single, max advance 36 deg, tri power, Dougs 4 tube headers. Untuned ,fun day at Norwalk/AMES, let the kid drive also, only real run with me was 13.43, 2.02 60', shift @ 5800 rpms. Best mph 102 something. No dyno, heads about worn out, bad valves/seats. New setup this winter only changes #96 heads, my porting flow 222I,175E @.500, chambers 84cc 9.3-1, and a 2004r w/2400 stall. Will dyno June 15th and race same day. I'll edit this at that time. Any guesses? Most miles driven in one trip 4000 in 10 days. It's a street only car.
Never poke a bear with a stick! Last edited by Bronze66; 05-22-2007 at 07:41 AM. |
69 Grand Prix J
428 cu KRE d ports comp cam 288 hr 850 holley, RPM intake 3.73 12 bolt 3500 redneck converter Liberty blue with black Leather Power everything 4200 lbs. 12.27 @ 109 1.72 60 ft. ![]()
Car: 1970 Pontiac GTO Judge
Weight: 3850 Engine: 412 CI Carb: 750 Quadrajet 7040270 (71 Jet, 39B rods, CE secondary rods) Compression: 10.5 Heads: Ram Air 111 (number 12 heads with slight clean up & 1.5 Harland Sharps) Pistons: TRW replacements .060 over Cranks & Rods: Factory crank & resized factory rods to .0023 Intake: Stock dual plane (…14.5” of vacuum at 900RPM) Transmission: Muncie (M-20) 4spd with a Ram diaphragm clutch Rear End: Stock 10 bolt with 3:90’s Tires: 28” BFG Radial Cam Specs: Ultradyne Hydraulic 223/231 & 468/485 lift @ .050, 106CL, lobe separation 112, .045 seat Operating Range: 2000-5800 RPM…shift points 5500-5800 (when racing… the car leaves the line between 2000-3000RPM) Ignition: Pertronix 11 (13 initial & 23 mechanical for a total timing of 36 degrees in by 2500RPM. Car use’s manifold vacuum, with the vacuum advance (B-3) limited to 10 degrees) Exhaust: Ram Air Manifolds have been Extrude Honed & mated to a 2 ½” mandrel bent down pipes, X-pipe with flowmaster 50 series mufflers. Current ET: 13.35 @ 103.1 (Poor 60 ft @ 1.97) Altitude: Low Fuel System: Airtek factory HO replacement pump (new hard lines and new fuel sock with 4-6 psi)
Buy a GOAT....they eat anything! |
Here are some specs on my mild 455 bracket engine. Now retired from racing, it will be driven on the street to local cruise nights and car shows. Hard-core race engine? Not even close.
1974 455 std. bore, pistons sitting at zero-deck (ranging from zero to -.005") from the factory. Original factory stock cast pistons / rings / rods / bolts / crank / bearings / balance job are all still intact, this short block is completely untouched. Hard to find a good 455 like this, I paid $100 for the entire running engine and then harvested the shortblock. I'm a thief. 1974 stock baffled oil pan, full-length stock windage tray, Mellings M54DS oil pump, HO Racing hardened oil pump driveshaft, stock oil filter adapter with the bypass plugged using a 3/8 pipe plug. 1971 #197 455 HO heads, pocket ported by a previous owner with a slight port clean-up, just enough to remove maybe half of the 'as cast' look inside the ports. The exhaust crossover is blocked off with an aluminum plate on the intake side, crossover passages are not filled. Milled .025", my guess is the stock 111cc chamber is now 105cc. Compression ratio calculates (guestimates?) to 8.6:1 with a .040" crushed head gasket. HO Racing HC-03 hydraulic cam and lifters (244/[email protected], 113 intake/120 exhaust LCA .550/.554" lift w/1.65 Erson stainless steel rollers). HO Racing 5/16" chome moly pushrods and VS-12 springs (1.71" installed height, spring seats cut) and stock retainers. Cam installed 4 degrees advanced using a Cloyes Tru-Roller 3-keyway timing set. 650 Holley double-pumper carb with stock jetting, only mod is a 50cc accelerator pump on the secondary side. Edelbrock Torker II intake with exhaust crossover removed and water crossover seperated, no porting/port matching or internal mods. Carb sits on a 1" open phenolic spacer. Stock 1974 aircleaner with a 2nd snorkel added, both are plumbed into the cowl for cool air. Distributor is a stock single-point with no vacuum advance and the mechanical advance mechanism locked out (38 degrees advanced), fired by an Accel coil and an MSD-6A box. It will be replaced with a recurved stock single-point distributor with working vacuum and mechanical advance for street duty, the MSD-6A box will be retained. HO Racing round-port Tri-Y headers (1-3/4" primary/2" secondary/2-1/2" collectors) dumping into a 3" home-made stainless steel exhaust with 3" #17547 (20" long case) Walker Dynomax Ultra-Flo Welded stainless steel mufflers, 3" tailpipes over the axle. There is no exhaust crossover of any kind on this system, it was built using all mandrel bends. Drivetrain consists of a TH400 w/transbrake and reverse-pattern manual valve body, stock flexplate/10" Continental converter (3500 flash stall), Ford 9" rear w/3.89 gears & 31-spline Detroit Locker/stock Ford axles, 28X10 Goodyear slicks. Best ET near sea level at Carlsbad Raceway on a warm August morning: 12.055 @ 110.29 MPH, 1.668 60' time. 1964 GTO 3550# race weight w/driver, a 5200 RPM shift point keeps the rods inside the block and produces the best ET. This low-compression 455 makes an honest 400 HP, runs on 91 octane. ![]() Same engine, updated a little for 2008 with a '71 455 HO intake and '77 800cfm Q-jet carb (big thanks to Cliff Ruggles) topped off with a '70 GTO twin-snorkel aircleaner. A recurved stock points distributor with vacuum advance (big thanks to Rocky Rotella) replaces the old locked points distributor. A new Rodney Red aluminum radiator with a '66-'67 upper hose location now takes on the cooling chores. |
| The Following 5 Users Say Thank You to b-man For This Useful Post: | ||
'76 Trans Am (original owner)
'69 WT 400 block .060 over,zero decked.hard block filled.4bolt splayed mains, '64 389 armasteel crank,balanced scat h-beam rods Ross forgred racing pistons w/total seal gapless rings. #48 heads,ported by me, Ferra stainless racing valves w/filled heat cross-over. Comp Cams magnum rockers 1:65 Comp Cams RAIV cam. '72 H.O. Aluminum intake w/Speed Demon carb. Hooker headers w/3" exhaust to rear bumper. Borg-Warner super T-10 w/centerline dual friction clutch stock 3:23 rear |
