Old 05-09-2007, 06:40 PM
69birdboy 69birdboy is offline
Default Detonation
I am having a strange detonation problem. I've never had detonation before.
Above about 4000 rpm and at full throttle, I am getting quite a bit of detonation. I haven't changed anything since last summer, and am still using the same premium gas.
I like the way it runs at part throttle, but want to get rid of the detonation at full throttle. What should I do?
69 firebird
Old 05-09-2007, 08:01 PM
79firebird_99TA's Avatar
79firebird_99TA 79firebird_99TA is offline
Is it the same gas?
Old 05-09-2007, 08:24 PM
No, I've been driving it year round, the gas has been changed about once a week.
I also checked the plugs, and they look good. Just checked the timing, and it's right where I set it last summer.
69 firebird
Old 05-09-2007, 09:02 PM
getmygoat's Avatar
Default timing?
Does the problem go away if you retard the timing slightly?
Did you quiet down the car in some way - for example, did you replace the exhaust system with quieter mufflers, etc?
Old 05-09-2007, 10:04 PM
Malky Malky is offline
Running hotter will cause this. Temp still the same?
Also running lean - fuel filter plugging, that kind of thing.
Old 05-10-2007, 08:18 AM
455_regal 455_regal is offline
springs in the distributor stetched-loose, letting it advance too much
PONTIAC POWER
Old 05-10-2007, 11:44 AM
Nope.
It's running at a good temp. It didn't show up until the weather warmed up a bit, though.
That's possible. I did use one of those mr. gasket advance kits in it, and those have a bad reputation for springs wearing out, but wouldn't the stops still stop the advance at the same total anyway?
69 firebird
Old 05-10-2007, 01:59 PM
steve's Avatar
steve steve is offline
my vote is for leaning out under WOT or extended high rpm driving (highway)....
crimped/blocked fuel line
clogged filter
dirty carb
did the car sit over the winter ?
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 05-11-2007, 02:00 PM
You may have been right about the filter. It was almost black with gunk. We'll see if that helps. Also, the car did not sit over winter.
69 firebird
