Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 05-24-2007, 10:50 AM
78 GHOST 78 GHOST is offline
Default M&H Electrical Fabricators
Folks, I wanted to post my results of using M&H for my electrical harnesses. M&H is VERY expensive, I think my 1970 GTO has about $1500 in wiring harnesses from front to rear..
..however, you do get what you pay for. The connectors, wire size/color, wrapping is exactly as it was in 1970. In fact, the harnesses come with the correct grommets for body passthrough pre-installed at the correct locations. The harnesses also have the correct clips and screw anchors installed at exactly the correct locations along the harness.
They had about 1/2 of my total order already on the shelf, the other 1/2 took a couple of months to produce.
IF you want the very best, and don't mind paying for it I HIGHLY RECOMMEND M&H Electrical Fabricators (562)926-9552
____________________________________
"I work in high speed aluminum tubing."
Old 05-24-2007, 01:51 PM
blue71ta's Avatar
blue71ta blue71ta is offline
I would agree. When I have purchased from them in the past, everything was top notch; would buy from them again.
Old 05-24-2007, 02:18 PM
sandmanjoe's Avatar
sandmanjoe sandmanjoe is offline
i got mine from PY, they sell the MH wires. at least they used to 5years ago
Old 05-24-2007, 03:21 PM
mwritter's Avatar
mwritter mwritter is offline
M&H did a custom '65 engine harness for me, and except for one incorrect HEI connector, it was awesome. I would not hesistate to order from them again.
Matt
1962 Grand Prix - Cameo Ivory|389 4sp|One-Owner Survivor
1964 GTO HT - Silvermist Grey|389 3x2s 4spd|A/C|Hurst Wheels|Frame-off|SOLD
1965 GTO Post - Mayfair Maize|421 3x2s TKO600|Pro-Touring|
1966 GTO HT - Barrier Blue|389 3x2s 4spd|Red Fenderliners
2005 GTO Coupe - Yellow Jacket|Magnacharged LS2 6sp|543hp/561tq|SOLD
2006 GTO Coupe - Spice Red|LS2 6sp|20k orig miles
Old 05-24-2007, 03:51 PM
Hitman's Avatar
Hitman Hitman is offline
Loved the points conversion they sell. Even a dummy like me can get it installed and working correctly.
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them.
Check out my sons blog, www.driftundertheradar.com
Old 12-22-2008, 08:50 PM
gtopont gtopont is offline
Default M & H
the parts from them are freat ! the wires were perfect and the 65 gto tri power temp sending unit worked dead on ! exactly 180 degrees ! everything was great..
Old 12-23-2008, 10:59 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is offline
I bought all my 65 GTO wiring from them. They were great. Now, I am using them for the wiring on my 67.
Old 12-30-2008, 08:27 PM
Norwood's Avatar
Norwood Norwood is offline
I have bought from them and HIGHLY recommend......
Old 12-30-2008, 08:45 PM
JLHarper's Avatar
JLHarper JLHarper is offline
Both myself and a friend on here with a Judge bought harness's from them and couldnt be more impressed with their quality and service.
The tech people know their applications too, and if you order say a AC compressor harness they bring to your attention the remainder of whats needed for that year AC compressor.
Order well in advance of when you need the part in case they run out.
Smilies are Off
