Old 06-03-2007, 02:24 PM
Default How soon can I put 2K over fresh epoxy?
It's PPG "Shop-Line" which as I understand, replaced the Omni brand.
I just scuffed up the old Omni epoxy that's been on for nearly a year. I'm ready to put down a fresh coat of epoxy and I want to know how long it has to cure before I can put the 2k on.
I find lots of info on the maximum window before you have to scuff and respray but nothing about the minimum time before I can coat with 2k.
Old 06-03-2007, 10:26 PM
No wonder I couldn't find it in a search...Nobody knows! LOL
Moot point now anyway...I'll do it tomorrow.
Old 06-04-2007, 01:34 AM
CDJr's Avatar
CDJr CDJr is offline
For DP, you can coat it after an hour, and Im sure the ShopLine or Omni would be the same.
A friend will help you move...a GOOD friend will help you move a body.
Old 06-04-2007, 04:40 AM
I figured I'd browbeat someone into committing. Thanks CDJr...
Old 06-05-2007, 07:37 AM
P455 P455 is offline
Here's the tech sheet for the ShopLine epoxy:
http://www.ppg.com/refinishftpsite/docs/JP370.pdf
http://www.ppg.com/cr-refinish/phase1/frmHome.asp
[insert witty signature here]
oops, double post.
Old 06-06-2007, 12:42 AM
Thanks P455. None of the P-sheets I found seemed to be concerned about the minimum curing time before topping with 2k so I guess it's not that critical. As a rule, I think I'd go with the advice above and wait one hour or more.
At any rate, I waited until the next day. Came out nice, I think.
It's come a long way from this!
