The Richmond 5 speed is not a OD trans.The Tremic shifts WAY better than the Richmonds IMO.Tom
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
Cool,will check it out!Still wont shift as good as the Tremic.Tom
Dave,
I just completed this swap about one year ago. I chose the TKO600 Kit from Keisler Engineering. I have a 1976 Trans Am which was a 4-speed, so your car should be exactly like mine as far as the swap goes. With the Keisler kit which included Tranny, Crossmember, Driveshaft, Speedo Cable along with add-ons such as the Clutch and Pressure Plate, Lakewood Steel Scattershield, and Hurst "Style" shifter, I was able to install this without drilling one hole or cutting one piece of metal. This is a direct bolt-on which can later be returned to original so that nobody will ever know!!! Why did I do it? Because I needed a tranny that would not self-destruct behind 500-600 lb-ft of torque. Are there fringe benefits? YOU BET!!! This car with a 500HP 462 has pulled a best of 22.4 MPG with 3.23 rears and 24.8 MPG with 2.41 rears. Best MPG I ever got with the factory stock 200HP 455 and 4-Speed was 12 MPG with stock 3.23 rears. However the 12 MPG was daily driving whereas the 22 and 24 MPG figures were under controlled highway conditions. Bottom line...This is some of the best money I ever spent on this car and I would do it again. And NO, I don't work for Tremec or Keisler. Just trying to share my experience. Hope this helps, David |
