| Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
md1twal3
I'm not a GM Tech, but I am a service engineer at GM. Is this a remote CD unit? If it is it could be a communication error between the CD unit and the head main unit. If the CD player is part of the head unit then all you can do is remove the unit and try to clean the lens with a qtip and lens cleaner. If this does not work then the unit will need to be sent to a radio repair shop. GM does not recommend the use of CD lens cleaner discs. The risk of contaminating the lens of the CD optics with lubricants internal to the CD mechanism. Sorry for the bad news, I have a 99 STS the remote CD changer works good, but the one disc player in the head unit gives me a CD error. Somthing happens internal to the unit that causes a no disc read condition. |
![]() Any further insight?
"My ol' man is a television repairman...he has an ultimate set of tools!....I can fix it..." J. Spicholi |
md1twal3,
Sorry I may have replied in hast. I looked over the service information and basicalliy the same applies. It appears that for some reason the player cannot detect or read the cd. If you are trying to read a cd that you recorded, the cd player may not be able to read it, try a different CD. I also found two TSB's that state trying to play a cd with wrong format will create problems, see below. TSB DVD Player Inoperative - keywords disc display entertainment movie #PIT3248A - (01/11/2006) and Info - Compact Disc (CD) or DVD Player Skipping, Inoperative, Sluggish and/or Long Search Times #05-08-44-001 - (01/24/2005) DVD audio discs are another high resolution sound medium that is offered to the consumer. This format is NOT compatible with a CD player or a conventional DVD Video player such as those offered by GM. The exception is that recently, some manufacturers of DVD-A discs have begun producing two-sided DVD-A discs. These discs may be labelled DualDisc with an accompanying symbol. Only DVD-A discs with this symbol will play in your GM CD/DVD. Sorry I can't be of more help, if you have tried differed CD's, then I suspect you will need to remove the player and send it out for repairs. Good luck
