Old 07-27-2007, 07:22 AM
spartazoo's Avatar
spartazoo spartazoo is offline
Default Definitive answer on door handles?
Is there a reproduced outside door handle set that will work on a 63 or do I need to get mine to the chromer?
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
Old 07-27-2007, 10:50 AM
azkeebler's Avatar
azkeebler azkeebler is offline
There is a posting on the little indians site where one claims the handles for a '69 camaro (which are common reproduction finds) will fit. They claim there is a very slight difference but wouldn't notice unless side by side. May want to compare yourself. Would to see chevy stuff on a poncho , though.
Old 07-29-2007, 11:48 AM
SDStanley SDStanley is offline
I bought some reproduction handles listed as "63-66 front and rear, 60 rear" for Pontiac full size models. They look identical and fit fine after trimming 1/2" from the stem which goes inside the door to trip the latch.
Old 07-31-2007, 05:24 PM
Poncho_Villa's Avatar
Poncho_Villa Poncho_Villa is offline
I replaced mine with ones from a 69 impala. Like SD stanley said....just had to grind down the finger that touches the internal latch. Looks just like the originals. Other GM handle from that era might also work. Let us know what worked.
Old 07-31-2007, 06:15 PM
68Prix's Avatar
68Prix 68Prix is offline
I think I have a set of 69 full size Chevy handles around here, If any one wants them to try feel free to PM me. Pat
Old 12-13-2016, 12:10 AM
Sanduners's Avatar
Sanduners Sanduners is offline
Interesting find when putting my door handles back together after getting them re-chromed. I used the best handles I had to get re-chromed and didn't know/notice that the part used to hold the button in place were different in thickness. When I went to install it wouldn't twist into place as it should and the first one did. I can see why they changed the design, the thin one will break out as you need to apply downward pressure while twisting.
ID:	442598   Click image for larger version
Old 12-14-2016, 11:18 PM
beemergary's Avatar
64 GTO will work but they tip down just a bit (know one will know). The rod behind the button is a little short. I cut and drilled a rod for the rod to slid in. Been good for last 12 yrs.
