Old 08-06-2007, 04:26 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default Fuel Line Routing on GTO?
Hey Everybody, I am trying to re-route my fuel return line off the regulator OUTSIDE the stock frame rails per NHRA. The line is an approved socketless material and needs to be away from the flywheel area. The regulator is mounted on the inner fender wells on the right side of the car.
Do people have some ideas and/or pictures to share? Thanks Again, CraigG.
Old 08-06-2007, 04:52 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
I ran my supply from the cell up through the frame area over the rear end, then back out to the outside of the frame rail...used adel clips to secure it to frame. It goes up the rail and then just outside the front outer body mount and up to my fender mounted regulator.. I use AL tubing for the long run along the frame.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
