Old 08-25-2007, 08:58 AM
sandmanjoe's Avatar
sandmanjoe sandmanjoe is offline
Default my heads wont bolt to the block HELP!!
unsure if this section is for ONLY pontiac race engines, but i have a major issue with this race boat engine,, its a 4bolt 350 1 piece seal block and i have these aluminum patriot heads,,, i started bolting them down this morning and all the bolts fit but the one on the end,,, there is NO hole!!
what the hell is going on!!
these are the heads, http://www.patriot-performance.com/w...p?x=1&DID=1225
i hope this mistake wont cost me 1000.00 dollars,
Old 08-25-2007, 09:14 AM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
It's an oil drainback hole. HTH
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 08-25-2007, 09:21 AM
sandmanjoe's Avatar
hahahaha,,, god im a dumbass,,, i guess i should have counted my bolts...
Old 08-25-2007, 09:47 AM
PONTIAC DUDE's Avatar
Thumbs down
Ahhhhhhhhhhhh. Chinese heads. LOL. Had some of those. rough castings.
Old 08-25-2007, 09:58 AM
sandmanjoe's Avatar
these are made in Alabama,, or so the guy said,,,, i was told they CNC these out after the order is placed. it took around 2weeks to get them. im also adding a 2in spacer on top of that hurricane intake lol
Old 08-25-2007, 12:05 PM
Wonder why the SBC don't have oil drain back issues the Pontiac aftermarket heads are supposed to? Even the factory SBC heads have little drain holes.
Old 08-25-2007, 01:54 PM
455Grandville's Avatar
455Grandville 455Grandville is offline
Skip - stroking a 409 ? Im guessing your doing some mods to a '54 crank to do that ?
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘67 Corvette 427/435
‘23 Lexus LS500 awd
‘20 Audi R8 & ‘25 Toyota RAV4 (wife’s cars)
‘95 Ford F250 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles & motorcycles
Old 08-25-2007, 05:51 PM
tikiklubracing's Avatar
tikiklubracing tikiklubracing is offline
Is that an Allen wrench sticking out of the water crossover access hole, or what. Just curious?????????
Hate to lose that down in there.
NHRA tech.
"Its just a 412, I swear it".
Pontiac tip of the year, quit those damn cigarettes.
Old 08-26-2007, 09:58 AM
Stroking a 409 is as easy as using a 3.76 396/427 crank pr a 4.0 454 crank and turnino the mains and counterweights down(and snout to SBC size) 409s had a 4.3125 bore and a 3.5 stroke originally. Get a 470 ci motor pretty easily. Down side even the good heads only flow around 250-270 cfm, hard to feed them just like our Ponchos.
Old 08-26-2007, 05:13 PM
Brian Baker's Avatar
I'm starting a pool on how long it'll take for that side to blow a head gasket...any takers?
Old 08-26-2007, 05:31 PM
sandmanjoe's Avatar
yes its an allen... there is no gaskets under anything on that motor,,, im just sitting all the parts on and putting all the bolts in the holes. its just on for looks right now. lol
Old 08-26-2007, 05:38 PM
sandmanjoe's Avatar
hey,,, do you guys use loctite on those allen set screws on the rockers??
Old 08-26-2007, 06:52 PM
Why do you think it will blow a head gasket just on that side????
Old 08-26-2007, 10:55 PM
Two reasons:
1.) I had assumed he already had the bolts (save for one) torqued down.
2.) Everything else he's worked on has some degree of "afro-engineering" in it.
Old 08-26-2007, 10:58 PM
No, absolutely not. Once you determine where you are going to have your final adjustment on the rocker nut, back it off 1/8" turn, then lightly bottom out the set screw against the top of the stud, then turn both the set screw AND the rocker nut the final 1/8" turn together. If you tighten the set screw AFTER you adjust the rocker nut to the desired position, it will eventually back off and you'll lose the set.
Old 08-26-2007, 11:46 PM
sandmanjoe's Avatar
got it,, glad i asked that question,, they came with no instructions and its my first time bolting rollers on an engine.
anything different i should do when bolting the aluminum heads to the cast block? im guessing i should re torque them a few times after running it. . thanks again!
Old 08-27-2007, 12:29 AM
Why would you want aluminum heads on a boat engine ? Unless its a closed cooling system.
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 08-27-2007, 11:22 PM
sandmanjoe's Avatar
its a closed cooling system,, this boat is heading to Deep Creek Lake in 1 month!!
heres some more pictures i took today with the 2in spacer and kick out oil pan
Old 08-27-2007, 11:30 PM
sandmanjoe's Avatar
the carb is going to sit 15in from the deck
the cam is----- lift .490/.490 dur 300/308
Old 08-28-2007, 03:10 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
Oops... sorry... I must have taken a wrong turn... I was looking for the "Pontiac Race" forum. 'Bye- have a nice day!
