Old 10-03-2007, 05:52 AM
firebirdcrazy1959's Avatar
firebirdcrazy1959 firebirdcrazy1959 is offline
Default Spoiler and flair prep?
The flairs are the pliable ones not the fiberglass ones just to be clear.What is the best way to prep the flairs on a 81 T/A for paint?I bought a very nice set but they are white and need to get them ready for paint.Do i just sand them with some lite grit to rough up the paint or take them down to the plastic.
1977 Trans Am,400 4 speed,numbers matching car
1979 Bonneville ,1 owner car...
1997 Trans Am convertible,LT1/auto.
Old 10-03-2007, 07:40 AM
79transam79 79transam79 is offline
Send a message via AIM to 79transam79
Default .
Hope you get some replies because I have the same Question. I have read that bead blasting is better than any chemical (because the chemical leak into the plastic) and as far as sanding I would think you would want to get down to the original surface seeing it's going to get chipped pretty easily. I started bead blasting mine seems to be working , it's only taking off the paint. But hope you get some replies from some autobody guys.
Old 10-03-2007, 04:43 PM
Me to,i don't want to mess up the plastic with scratches.
Old 10-04-2007, 12:33 PM
RASK's Avatar
RASK RASK is offline
Post under your year T/A tech, you'll most likely get the answer there. Worst case you could alway wet sand, no one is going to argue that method. I wet sanded my hard style and it did not take that long. Paint I'm sure, would be the same as for flexible parts. Follow paint manuf. recommendations. Can't remeber if flex flares have welting, if so, paint separetly then put them on afterwards.
'73 Buc Red T/A, 4 speed, A/C, Std Black Interior
"If you choose not to decide, you still have made a choice" RUSH (Freewill)
Old 10-04-2007, 09:50 PM
ronj1977's Avatar
ronj1977 ronj1977 is offline
i used fiberglassstripper on my rear flairs (77 t/a) ate the plastic in some spots had to sand plastic down in order to remove gauges left from stripper eating plastic.
