Old 10-26-2007, 09:44 AM
Steve C. Steve C. is offline
Sorry if I made any typo errors, here it is again...
Torker II
4000 rpm 398 hp
5700 rpm 566 hp
HSD
4000 rpm 401 hp
5600 rpm 589 hp
Performer RPM
4000 rpm 423 hp
5800 rpm 580 hp
Victor
4000 rpm 402 hp
6000 rpm 600 hp
All intakes tested with a 1/2" open carb spacer and the same HP950 carb.
And all intakes port matched to my heads except the Torker II
Old 10-26-2007, 10:01 AM
Since my T2 was more opened up and stayed with the Holley, so probably could be better numbers than the one Steve tested.
Most dual planes I have flowed had different numbers for upper and lower plenums on almost every cylinder. The larger plenums and runners on an RPM over a stock intake might be a little better but I've seen 5% difference between upper and lower runners.
