#121
Old 10-31-2007, 08:14 PM
67'7F6'Bird's Avatar
Pictures of the rear roof brace clamped down and welded on.
ID:	109853   Click image for larger version
ID:	109854   Click image for larger version
ID:	109855   Click image for larger version
ID:	109856   Click image for larger version
  #122
Old 10-31-2007, 10:02 PM
All Roof braces completely welded on. I then dressed the plug welds, cleaned them with Picklex, then sprayed Rust Encapsulator over the cleaned surfaces. I did have burn through on the rear brace which I'll weld up tomorrow. Completing this means there are no more panels being cut off -YEAH!!!!!!
ID:	109864   Click image for larger version
ID:	109865   Click image for larger version
ID:	109866   Click image for larger version
ID:	109867   Click image for larger version
  #123
Old 11-04-2007, 08:17 PM
We did some Roof fitting today, it went very well. I cleaned out the drip rail completely and did some grinding and hammering on the front area of the roof where it meets the pillar post. For final fitting we will use the ratcheting straps to pull the roof as low as we can so it sits flush in the drip rail area.
ID:	110187   Click image for larger version
ID:	110188   Click image for larger version
ID:	110189   Click image for larger version
  #124
Old 11-04-2007, 08:19 PM
More Roof Pictures.
ID:	110191   Click image for larger version
ID:	110192   Click image for larger version
ID:	110193   Click image for larger version
  #125
Old 11-11-2007, 10:38 PM
We began our final assembly one last time to make sure we didn't miss anything and to make sure all our plug weld holes were aligned properly to all inner structures. We left all panels on the car and began our welding on the drivers side quarter panel. We only used the Fuser Adhesive in the drip rail area. We applied the weld through primer on the inside of the panels.
We welded in the following order:
1) Quarter Panel to Rocker Panel
2) Door Lock Striker area to inner bracing
3) Quarter panel to inner bracing (outermost portion)
4) Door Jam Lip Horizontal from right to left
5) Door Jam Lip vertically from the bottom up
We will next do the same on the other quarter panel before we move on. All panels are in place and clamped together. We spent about 6 hours Saturday hole punching panels and spraying them with weld through primer, and final reassembly.
ID:	111037   Click image for larger version
ID:	111038   Click image for larger version
ID:	111039   Click image for larger version
  #126
Old 11-11-2007, 10:51 PM
We dressed the welds - one of those days!!!!!
Wiped everything clean with Picklex and then sprayed on some Rust Encapsulator.
We placed special attention to where the quarter panel sits on the rocker, the gap is very tight and we will apply seam sealer when all the welding is completed.
ID:	111044   Click image for larger version
ID:	111045   Click image for larger version
ID:	111046   Click image for larger version
ID:	111047   Click image for larger version
  #127
Old 11-13-2007, 02:54 PM
Here is a close up of the drivers side Wheel Well area. The Quarter Panel is not yet fully welded. We then moved to the passenger side Quarter Panel and followed the same welding order as the drivers side.
Next step is to weld and glue in the rear valance panel.
ID:	111278   Click image for larger version
ID:	111279   Click image for larger version
ID:	111280   Click image for larger version
ID:	111281   Click image for larger version
  #128
Old 11-13-2007, 06:54 PM
YVEYANT's Avatar
YVEYANT YVEYANT is offline
Send a message via AIM to YVEYANT
You are doing an amazing job. Before you know it, you will be ready for battle!
Ant
1967 Pontiac Tempest, GTO-Inspired
"What's so special about having Italian food cooked by a bunch of friggin Mexicans"
Paulie-
Rocky Balboa
"Your heart is free, have the courage to follow it"
Braveheart
http://i106.photobucket.com/albums/m...Wm0SlqN030.jpg
  #129
Old 11-17-2007, 10:12 PM
Thanks Yveyant, I can't wait to start her up again, much more planned for the drivetrain too.
Your paint looks great too!!!
We had time to Glue/Weld in the rear Valance Panel.
We used glue only on the seam where it meets the rear quarter panel.
We used the SEM Copper-Weld Primer on the panels where they meet one another for the plug welds, again this stuff works great!!!!
We still have to get used to the glue, always missing the right clamp when you need it.
The Plug welds came out great - only needing a little sanding with the right angle sander, using 2" diameter 80 grit paper.
It looks like my brother got some action shots.
ID:	111749   Click image for larger version
ID:	111750   Click image for larger version
ID:	111751   Click image for larger version
ID:	111752   Click image for larger version
  #130
Old 11-17-2007, 10:20 PM
We placed some 2x6 's in the trunk to sit and kneel one, anything to make it more comfortable when your welding.
I did apply Picklex and Rust Encapsulator to all the welds.
We hope to get the tail panel welded in Sunday.
I'll get some close-ups of all the gaps/seams tomorrow and post them too.
Thanks for looking!!!!
ID:	111755   Click image for larger version
ID:	111756   Click image for larger version
ID:	111757   Click image for larger version
ID:	111758   Click image for larger version
  #131
Old 11-19-2007, 07:01 PM
Here are some photos of where the tail panel meets the quarter panel. We started welding from the inside right above the hump where the bumber covers and worked our way up one plug weld a time. After both sides were completed in this area we put the two plug welds in the recessed area in the tail panel. All welds underneatht the car will be completed at the same time, wheel wells, trunk drop-offs to quarter, tail pan to inner pan, although we did have them all clamped together.
I did notice that on each quarter panel their stamped upper rear curves are unique and I will have to lead-free the passenger side to match the more pronounced curve of the drivers side. I will also lead-free the bump out on the tail panel where it meets the quarter, as the stamping drops off instead of going straight across.
ID:	111978   Click image for larger version
ID:	111979   Click image for larger version
ID:	111980   Click image for larger version
ID:	111981   Click image for larger version
  #132
Old 11-19-2007, 07:11 PM
Here is where we started on the inner area of the tail panel. We then moved on to the trunk pan to tail panel with using the large clamp to make the welds flush.
I love that last photo - almost done!!!!!
ID:	111983   Click image for larger version
ID:	111984   Click image for larger version
ID:	111985   Click image for larger version
  #133
Old 11-21-2007, 01:10 AM
Tonight we were able to complete the lower area of the quarter panel where it meets the trunk drop-offs. We did need to slice the tail panel (about 3 inches long cut off wheel thickness) where it meets the quarter in the very bottom. I will post pictures of that tomorrow. If your wondering we have plent of clamps!!!!HAHAHA
ID:	112121   Click image for larger version
ID:	112122   Click image for larger version
  #134
Old 11-21-2007, 01:21 AM
RLEbird's Avatar
RLEbird RLEbird is offline
The louvers on the replacement quarters are slightly shorter than what they were from the factory. I think Ames still sells shorter chrome louvers that will work for aftermarket quarters.
  #135
Old 11-21-2007, 11:44 PM
Hello RLEbird: I installed my GM louvers and they fit perfect.
Here are the final welded passenger side trunk drop-off pictures. To be painted soon.
The Tail Panel shows the slice we needed to put in to it for a better fit.
ID:	112215   Click image for larger version
ID:	112216   Click image for larger version
ID:	112217   Click image for larger version
ID:	112218   Click image for larger version
  #136
Old 11-22-2007, 12:37 PM
Here is the drivers side trunk gutter being reshaped. We penciled a line on the first picture so we knew were to cut using the saber saw/ high speed cut-off.
We used a hammer and punch and attached a large clamp at the tail panel edge and used a large screw driver to manipulate the very end of the radius flush to the tail panel and then spott weld it there. Thats when teh hammer and chisel came into play.
Used B 6 on the Mig and started from the top and pulled the weld toward me.
ID:	112243   Click image for larger version
ID:	112244   Click image for larger version
  #137
Old 11-22-2007, 12:41 PM
We then sanded it with 60 grit paper, wiped it clean with Picklex then sprayed some rust encapsulator and moved to the passenger side. Gutters to be welded next.
ID:	112246   Click image for larger version
ID:	112247   Click image for larger version
  #138
Old 11-27-2007, 07:02 PM
Here is the Passenger Side Quarter panel gutter being fixed.
ID:	112746   Click image for larger version
ID:	112747   Click image for larger version
ID:	112748   Click image for larger version
ID:	112749   Click image for larger version
  #139
Old 12-08-2007, 08:51 PM
We got the trunk gutters completely installed, overall they were a good fit.
The Extreme DynaMat arrived this past week and we applied it to the underside of the roof. The roof in this photo is just sitting in place. When we clamped it down it is very tight to the roof bracing.
Steve
ID:	113940   Click image for larger version
ID:	113941   Click image for larger version
ID:	113942   Click image for larger version
  #140
Old 01-11-2008, 07:30 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Talking
I know you’ve really busy with the holidays and all, but when do you plan on welding to roof on?
