#61
Old 07-22-2007, 12:30 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Originally Posted by mike nixon
patrick, out of curiosity, did you find a vin stamped in the frame or had it rusted away? if you did restamp the new frame in the same location after cleaning it up. it'll save a lot of hassle if the car ever gets inspected.
mike
Mike,
I think I have read that the VINs did not start getting put on frames & blocks on Pontiacs until 1967 even though the law went into effect in '66.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
  #62
Old 07-22-2007, 01:38 PM
65WJ's Avatar
65WJ 65WJ is offline
I did determine that it is an A O smith frame and not a parish. Has 2 holes by the steering box not one.
patrick
  #63
Old 07-22-2007, 03:12 PM
Originally Posted by Deadhead
Mike,
may or may not have been law but my 57 international has the vin on the frame.
i just sold a buddy a 41 plymouth and it had an engine tag, body tag and a tag on the frame that was unreadable.
mike
former." --Albert Einstein
- Winston Churchill
  #64
Old 07-22-2007, 03:19 PM
Originally Posted by 65WJ
Mike
Open house on the 29th. Have not heard if the yard has moved.
Only found 2 numbers a 5 and 8.
Just too pitted to find anything
I did read somewhere that once the steel is stamed the stamping is in the metal and can be retrieved. I would like to know how.
Chasing parts is fun.
Patrick
that all depends on how much penetration the welder has when the stamping's filled.
as i said if the car ever gets inspected by law enforcement and the numbers don't match it could open up a big bag of worms. according to the isp detective i talked to the chassis is what's titled. the visable vin, the frame and the drivetrain numbers should match for a legit car.
mike
- Winston Churchill
  #65
Old 07-22-2007, 03:54 PM
Stuart's Avatar
Stuart Stuart is offline
Mike,
They did put the VIN on the block for a while in the early 60s, although I don't recall the exact years. My '61 has the VIN stamped on the block. Don't know about the frames.
  #66
Old 07-22-2007, 07:55 PM
65WJ's Avatar
So I will just keep the original frame. I do not know how or where to store but will find something. Just like moms gto as long as I am alive neither her gto nor my 2+2 will ever be sold.
patrick
  #67
Old 07-26-2007, 04:46 PM
65WJ's Avatar
Default selling with a different frame
Mike
I called my freind at the State Police as well. I was sent to the BMV. Everything is fine. The body has the correct tags. All the BMV said was to keep the title from the doner car.
Patrick
see you Sunday
  #68
Old 11-02-2007, 06:36 PM
65WJ's Avatar
Just an update. Has been real slow getting the frame from the parts car. Many thanks to Steve at Indiana Pontiacs and Mike Nixon for helping. It was a cold misty day. But a fun day. Redi strip called today and I will pick it up on Monday.
It is very very nice. Only one very small 2-3mm hole that needs plugged. The cross member brackets need to be straightened just little.
One thing I noticed the front sway bar off the Grand Prix is 5/8th and my 2+2 is 3/4.? Visually looking I did not measure.
Heavier sway bar part of the heavy duty suspension. (your thoughts Mike.)
Core support came out very nice as well. One small patch under the battery tray and it will be excellant.
I will post some pictures Monday Night.
Patrick
  #69
Old 11-04-2007, 01:29 PM
the handling pkg ,from memory here, consisted of the larger sway bar, heavier spring rates and a different tire size. your 'vert already had the hd frame in place.
that frame's a nice peice.
mike
- Winston Churchill
  #70
Old 11-05-2007, 08:28 PM
65WJ's Avatar
pictures of new frame and core support.
much better than the original.
patrick
ID:	110298   Click image for larger version
ID:	110299   Click image for larger version
ID:	110300   Click image for larger version
ID:	110301   Click image for larger version
  #71
Old 11-05-2007, 08:30 PM
65WJ's Avatar
more of the frame and core support the one small rust hole that needs plugged
ID:	110303   Click image for larger version
ID:	110304   Click image for larger version
ID:	110305   Click image for larger version
  #72
Old 11-05-2007, 08:59 PM
patrick, is that the support off of the body i have here?
they both cleaned up nice.
mike
- Winston Churchill
  #73
Old 11-05-2007, 09:33 PM
65WJ's Avatar
Mike
Yes it is. Just the one area under the battery box that need repair.
Do you need it? I have 2 more but one is not very good.
Patrick
  #74
Old 11-06-2007, 12:03 AM
64catdroptop's Avatar
64catdroptop 64catdroptop is offline
Patrick,
There is something wrong with your frame - I'm not seeing any rust holes!!!
-r-
Never trust anything that bleeds for five days and won't die.
  #75
Old 11-06-2007, 12:50 AM
Originally Posted by 64catdroptop
Patrick,
-r-
give it time ron, give it time.
mike
- Winston Churchill
  #76
Old 11-06-2007, 12:51 AM
Mike
Patrick
no, not at this time anyway. i was just asking.
mike
- Winston Churchill
  #77
Old 11-10-2007, 07:50 PM
65WJ's Avatar
Default finally some progress to report.
Yeh finally some paint. DP90LF primer sealer. But look its black. It is so pretty.
Have to order the paint. Keep these warm day for a little while longer.
Thanks to Ron @ clearcreek restorations for his advice on the DP90LF
More coming soon.
ID:	110964   Click image for larger version
ID:	110965   Click image for larger version
  #78
Old 11-10-2007, 09:35 PM
Hitman's Avatar
Hitman Hitman is offline
Where on the frame is that stamp?
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them.
Check out my sons blog, www.driftundertheradar.com
  #79
Old 11-12-2007, 09:51 AM
65WJ's Avatar
Hitman
Check the right rear corner. (passenger side rear)
patrick
  #80
Old 11-20-2007, 10:04 PM
65WJ's Avatar
After the sealer, frame is now primed. After Thanksgiving will get the final paint on.
ID:	112103   Click image for larger version
ID:	112104   Click image for larger version
ID:	112105   Click image for larger version
