Hi everyone,
I going to remove my driveline this winter and I am just gathering info.,as I have not done this in close to 30 years. Do I need a special tool to remove the pilot bushing ? How is it done? Also would you replace it with a bearing or go back with a bushing? Where can I get one also? Thanks, Dave
Never use a pilot bushing in a Pontiac engine. The bearing is available at any good parts store. The BCA # is 7109.
The difference between inlaws and outlaws? Outlaws are wanted |
And what is BCA? Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill |
Dave: There is a special tool. Here is a pic of one. I also used a bearing when replacing..
Charles Last edited by chuckies76ta; 07-21-2011 at 06:36 AM. |
Same ??? as Murf's Dad.
Why not use a bushing? What does BCA mean? Also is there a name for that tool? Can I rent at a parts store? Thanks, Dave |
Dave: The bearing is a sealed pre greased bearing and my thoughts are that it will last longer, and is stronger.
BCA, I believe is a standard. BEARING CORPORATION OF AMERICA. Like CSA is Canadian Standards Association. The tool is called a 3 Jaw bearing puller or pilot bearing puller. I think it cost under $20.. I bought it here in Canada at Princess Auto.. Charles |
Here is one at Harbor Freight.. Hope this is of some help
Charles List of store locations: http://www.harborfreight.com/cpi/ctaf/retail_stores.taf Here is the tool. http://www.harborfreight.com/cpi/cta...temnumber=4876 |
Will this tool pull bushings as well or only for bearings? Stewart
I've use that puller from Harbor Freight to pull my old bearing. My car came with a bearing stock if my memory serves me.
Stewart
Stewart: I used it to pull mine as it was a bushing. I then installed a new bearing.
I'm going to edit as you just posted..lol My stock one was a bushing.. Charles |
I could be wrong on the bearing but I don't think GM started using the pilot bearing until it went to the diesel in cars and that was after traditional Pontiac motors died. If I'm wrong some will step up and correct me, I know. Stewart
I haven't pulled a '70's manual trans Pontiac apart, but I have never seen one with a bushing from the factory, I've had probably 30+ apart, they all came with bearings.
Randy W 1975 Firebird third owner. 1980 Grand Am/black/beaurdeaux/45000 mile original owner.(Now belongs to Iowapub.) '67 Impala SS (sold) |
Thanks everyone. I am ordering the tool and I am going with a bearing.
Dave |
I have used the Bearing type Pilot in the past (in the early days) and hammered a couple of the bearings with powershifting, (the bearings would no longer turn smoothly).
When I went to a Lakewood Scattershield I also used the "block saver" plate so that spaced the input shaft the thickness of the plate farther out too. At that point I went to a machine shop with some bronze "oilite" material and had them turn me a few of the bushings that were the same OD (+.0005) and ID except now the bushing length was longer. I have never hurt the transmission input bearing since but I did hurt it with the original bearing type input shaft bearings. The bushing will take a lot of abuse with at best very slight distortion (enlarging of the hole). JMO Tom V.
I stand corrected.
Thanx guys, Stewart
"What I was told is that no PONTIAC built engine (up to 81) takes a pilot bushing as it may put a thrust on the crank. Every original Pontiac engine that I have seen has a bearing." The rear main of the crank is supported very well (very wide bearing). No bushing if centered on the centerline of the crankshaft and the transmission will put a thrust on the crankshaft. Therefore the "thrust" you refer to must be in a front to rear motion. If the bushing is installed correctly (where the transmission input shaft has clearance between it and the bushing (at the large splined area) then there should be no thrust there either. Can you explain further? Like to hear the reason why. Tom V.
If there was no reason, why did Pontiac spend the extra money for 28 years, to use bearings instead of bushings? Many Chevy racers use to machine their cranks to accept bearings.
. I've always used a rod and filled the cavity with grease. smack the rod with a hammer and it pushes the bushing out.
