Old 11-27-2007, 02:00 PM
raj raj is offline
Default 7M5 heads
I have a 1973 455 I'm going to rebuild eventually. I disassembled it and found it did in fact have 4X heads with press in rocker studs. THere is a guy in a local shop I was talking to and he said he had access to a set of 7M5 heads that a customer never picked up.
Is it worth upgrading to 7M5's from 4X's? I'm not going to have too serious of a build. What are 7M5 heads worth as cores or needing rebuilt? Thanks.
Old 11-27-2007, 03:19 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
They're far too similiar to offer any real performance benefit. About the only difference is the 7M5s larger exhaust valve. I'd suggest small-chamber 4Xs (ie 4X-7), or 5C or 6X heads for a compression boost.
Old 11-27-2007, 03:21 PM
amcmike's Avatar
amcmike amcmike is offline
There okay if you're building a turbo engine (huge chambers). They are also missing the end bolt bosses for the exhaust flange so your prone to leaks unless you have some material to tap new holes. What are they worth? Well I asked $50 for a set of cores and everyone laughed.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 11-27-2007, 09:11 PM
raj raj is offline
Well, I'm a little new to the Pontiac scene. I'd figure that 7M5's use screw in studs. In stock form, they should flow a little better than later heads. Is this correct?
Thinking about it, the guy at the shop may have been hinting they'd already been rebuilt. I probably won't go through with the deal unless it's a really good one.
Old 11-28-2007, 03:57 AM
Will Will is offline
They don't flow any better, and as mentioned are missing the end exhaust bolt bosses, which makes header installation a pain. Stock manifolds are fine though.
I don't think the 7M5s have screw in studs, either. Only heads with the big intake valves (2.11" intake) got screw-in studs prior to mid year '73. After mid year '73 all heads got screw-in studs.
I'd do as Rocky suggests. The head castings he mentioned will have the big intake valves, screw in studs, smaller combustion chambers, and all of the necessary bolt holes. They're not too hard to find, either.
Old 11-28-2007, 10:30 AM
Will's right, 7M5 heads do not have threaded rocker arm studs.
Old 11-28-2007, 04:09 PM
raj raj is offline
I think I'll steer clear of them if they don't have screw in rockers. I'll probably steer clear of them either way though. Just thought maybe they would be good for a mild build and if I could get them cheap.
7M5's didn't come with 2.11 intakes? What about my 4X's? Just curious about this.
Old 11-28-2007, 04:17 PM
Half-Inch Stud Half-Inch Stud is online now
I owned a set of 7M5s and had the screw-in stud KEEN-SERTs installed. Nicely done & affordable.
Drill &Tap the EXH Flange end-holes (4 places) gets the 7M5s to Ram Air III casting parameters (aside from compression). Mine were the 2.11/1.77 combo. Good blower head.
Old 11-28-2007, 05:41 PM
steve's Avatar
steve steve is offline
HIS...could you provide more info on KEEN-SERTS ??
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers....
Old 11-29-2007, 02:11 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
Is there any difference in the valve seats. Thought the 6xs were more forgiving than the earlier heads with unleaded gas.
Old 11-30-2007, 08:48 AM
PONTIAC DUDE's Avatar
Post FWIW:
There are studs made with 1/2" X 7/16" to fit the press in style heads without using heli coils.
I have a set of the 7M5 heads for sale. Take offs of a 455. Hav the big valves with press in studs. No outer exhaust bolt holes.
Old 11-30-2007, 10:26 AM
Ollie's Avatar
Ollie Ollie is offline
Default 7M5 Heads
I have a set of 7M5 Heads also.
Anyone can have them for the shipping cost
Its ok to giggle and snicker, Dont laugh and point
Old 12-01-2007, 05:31 PM
Asked Jeeves, for http://www.newmantools.com/kee.htm
and it looks like the right item. Cheaper & more righeteous fit to the pressed-holes, than Heli-coil parameters.
Old 12-01-2007, 10:29 PM
Or, as P-dude says, just pull the pressed studs, tap the resulting hole for 1/2-13 threads and use the ARP studs with 1/2-13 bases and 7/16" tops. Easier, faster, cheaper.
Old 12-02-2007, 01:10 PM
Wink
Might want to re-consider.................
http://cgi.ebay.com/ebaymotors/ws/eB...174707132&rd=1
