Old 12-21-2007, 05:14 PM
pete315 pete315 is offline
I'm rebuilding a 73 455 with 71 #96 heads. which cam should I use. car is to be street driven. Summit 2801 or the 068 cam?
73 Grand Am 455 Muncie M20 4 speed 3.23 gears
Old 12-22-2007, 02:56 AM
67drake's Avatar
67drake 67drake is offline
Give Ken a call and he'll take care of you.Click on the link in his signature for his #.His shop is closed till Jan 7th though.
‘55 Catalina
Old 01-15-2008, 09:44 PM
67drake's Avatar
Just figured I'd update my old thread in case it helps anyone doing a search in the future.
I just ordered the 60242 that Ken "Ace" Brewer suggested above. Since posting this thread I've decided to update the stock bottom end,so I can safely spin the engine higher than with my original cam choices. I had a hard time choosing between the 60916 or the 60242 since they are so similar. I chose the 242 because it should work a little better with the 9.1-9.2 CR that I will be running. Seems like the minimum for the 916 is around 9.5.
I'll update again when I get the engine on the dyno or to the track.
Drake
‘55 Catalina
