Old 12-22-2007, 04:25 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Default Anyone ever use "elephant ears" as a motor restraint?
I want to hear from people that have used them...plates from frame to front of heads on both sides. Any head gasket problems? I do not want the typical "that won't work because...." from people who have not tried it. Real world experiences only please.
I am considering using them on both sides in addition to the stock mounts I currently use. They would be mounted to the heads with 3 bolts per side. I will add front and mid plates at some point, just not now.
I know people have done it. I just want to hear what experiences people have had.
Thanks.
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 12-22-2007, 04:46 PM
Apache Warrior's Avatar
Apache Warrior Apache Warrior is offline
Default E-ears
Darin, I am using them currently with no problems to date. My best ET so far is 11.78 @ 115
Here are some before and after pictures. Before being when I got the '63 back home from the fabricater - After being with my current motor installed in the car.
ID:	115341   Click image for larger version
Name:	HPIM0188 (Medium).JPG
ID:	115342   Click image for larger version
Name:	HPIM0189 (Medium).JPG
Old 12-22-2007, 04:58 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Im considering something to that tune but I'm starting to lean towards a motor plate so I have a mounting location for a vacuum pump. Mid plate will not work for me due the the headers. So I will use a plate with the regular mounts. If you use the front and mid plate only you need the lateral bars in place.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 12-22-2007, 05:19 PM
taff2's Avatar
taff2 taff2 is offline
A friend of mine has used them on his mild race car for about 10 years without any problems. His are homemade steel and used with stock type motor mounts. Car runs 11.50,s with a 400 motor.
Old 12-22-2007, 05:59 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
I use them in the sprint boat with shifts of over 4 lateral G's in less than a second
Mine uses a motor plate (steel) behind the timing cover and picks up on one of the accessory bolts in the face of the heads
This allowed some support above the COG of the engine to help restrain it and stop it bending the mounts under high G cornering
I also use a full rear motor plate
ID:	115346   Click image for larger version
ID:	115347   Click image for larger version
Working on going faster (and now staying dry at the same time !!)
Old 12-22-2007, 06:02 PM
I've used 3/8ths chain from drivers side(head bolt hole closest to timing cover) to frame in same manner without issue in the 11.70's range. Sure was better than broken mount and resulting pulled throttle cable that happened prior to doing so!(big bang just before 60 ft and lift pedal and still accelerating hard gets your attention quick) I see no issue in doing it your way if not using as only mount.
Old 12-22-2007, 06:48 PM
J H Performance J H Performance is offline
I use them and a midplate on my dragster with no issues. A friend of mine used them on his tube chassis firebird with no problems.
Old 12-22-2007, 06:54 PM
goatroper's Avatar
goatroper goatroper is offline
I use 1 steel rod connected to the head and frame on the drivers side of my car. I also use stock rubber motor mounts. It goes 10.80's and never a problem with head gaskets.
Old 12-22-2007, 07:16 PM
I use them in my dragster, no problem.
But I think if you have the stock mounts, I'd just use a chain or something to control movement. Really only need it on one side.
Old 12-22-2007, 07:25 PM
Jagtec1's Avatar
John, I use an air pan to seal the carb to the scoop. I'm not only trying to help with transfer of torque, but am also attempting to prevent the motor from "dancing" at idle, and otherwise. Hood is not liking the abuse!
I think I'll use them. I got 2 nice pieces of Aluminum, just over 1/8" thick. I'll weld up some angle to the frame, and bolt the plates to it. I'll post up pics when done.
Darin
9.81 @ 136.39MPH
Old 12-22-2007, 08:01 PM
fast72lemans's Avatar
fast72lemans fast72lemans is offline
Send a message via MSN to fast72lemans
I use them as well......never a problem due to plates.
Name:	saved pictures 942 (Medium).jpg
Old 12-22-2007, 08:13 PM
Ron's Avatar
Ron Ron is offline
Dump the stock motor mounts and use the elephant ears. Elephant ears for 10+ years without problems.
Due to the current economic conditions...the light at the end of the tunnel has been turned off.
Meet you at the finish line.....don't be late!
Old 12-22-2007, 08:53 PM
Jagtec1's Avatar
I will retain the stock mounts and add the "ears". Thanks all!
Darin
9.81 @ 136.39MPH
Old 12-22-2007, 09:32 PM
Ron's Avatar
Ron Ron is offline
My opinion.....you could find yourself fighting between the elephant ears and stock motor mounts and IF and I say IF they were not perfectly aligned could cause a bind and possible a break or failure somewhere. The elephant ears are more than enough to support high HP motors and the chain support is also capable of supporting high HP motors but...again in my opinion you could fine them fighting between themselves.
Regardless of your decision.....have fun and enjoy your ride.
Old 12-22-2007, 10:03 PM
Jagtec1's Avatar
So you are running only ears and a tranny mount?? I can't see that working well...too long of a distance between mounts. Or are you running a midplate?
Darin
9.81 @ 136.39MPH
Old 12-22-2007, 10:52 PM
Ron's Avatar
Ron Ron is offline
I run a mid plate, front plate, and a poly trans mount with elephant ears. Been this way for over 10 years without a problem.
My new car will run a full front plate from BOP with a mid plate and a poly trans mount.
Old 12-23-2007, 12:01 AM
Old Man Taylor's Avatar
I have been running the elephant ears for a long time. At first with the front engine mounts, and now without them. I have a poly trans mount and no mid-plate.
Name:	Elephant Ears 002 small.jpg
Old 12-23-2007, 12:02 AM
Goathead's Avatar
Goathead Goathead is offline
Send a message via AIM to Goathead
Ron and Jim, why not prefer polly tranny mount?
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC]
http://www.youtube.com/watch?v=iJrDl3nRNCM
http://www.youtube.com/watch?v=Fvywdocl4GA
http://ultimategto.com/icongraf/65headtitle.jpg
Old 12-23-2007, 01:36 AM
Ron's Avatar
Ron Ron is offline
Cost....have you ever priced one???
Old 12-23-2007, 01:41 AM
Probird's Avatar
Probird Probird is offline
Ditto to what John said. I use the stock mounts and a chain on drivers side head only. No problems running 9.80's.
