Old 01-10-2008, 01:25 PM
drtex drtex is offline
Send a message via AIM to drtex
Default 68 lemans frames
Does anyone know if theres a vast difference between a 68 lemans frame and tha 70 model?
Old 01-10-2008, 02:40 PM
Herrorhh Herrorhh is offline
There shouldn't be any differance 68-70. Remember though that there is a difference hardtop to convertable.
Cheap, Fast, or Reliable...Pick two...
Old 01-10-2008, 02:50 PM
triathlonx13's Avatar
1968-1972 Tempest, GTO, Lemans hard top frames are all the same. 1968-1972 convertibles are all the same to. A convertible frame will work in a hard top (just has a box section alone the rocker area. Don't use a hard top frame on a convertible car. The box section give the car more strength that the convertibles need.
ps. 1968-1972 Skylar, Chevelle, Cutlass frames can be used - Their all "A" bodies. Motor mount holes may or may not be the same??? I'm not possitive.
Old 01-10-2008, 07:19 PM
GStage1's Avatar
GStage1 GStage1 is offline
68 is slightly different cosmetically in the cross-member under the engine. Has to do with the "tongue" design.
All A-body models share the same frame for 2 dr coupes. All convertibles share the boxed frame from 68-72. I no longer have a picture of the 68 GS400 that I stripped for parts and sold.....but there is a difference if you know what to look for on the frame. Unless the cars is a concours show car, no one will know.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 01-10-2008, 07:24 PM
6704gto's Avatar
6704gto 6704gto is offline
68-72 frames are the same xceopt the verts have more bracing
