Old 01-22-2008, 06:10 PM
1lemans 1lemans is offline
Default install larger fuel line ?
when fitting a larger fuel line where on tank is best position? what about original line coming through sender unit do i remove it and put larger one in its place?no idea im new to high horsepower applications any help would be greatly appreciated thanks.i forgot to mention its a 68 lemans.
Old 01-22-2008, 08:42 PM
RobbMc's Avatar
RobbMc RobbMc is offline
These will be available in about two weeks:
http://www.robbmcperformance.com/pro...ndingunit.html
Old 01-22-2008, 08:47 PM
Silver Judge's Avatar
Nice piece there RobbMc !
501 HP, 554 ft lbs TQ
Old 01-22-2008, 09:42 PM
Big Injun's Avatar
Big Injun Big Injun is offline
Robb...I could use one of those for my GeeTOW Wagon. Thank looks like a great new piece.
If you do not go with the new RobbMc unit you can do what we did with the GeeTO Tiger and what I plan on doing to my wagon tank. I installed a bulkhead fitting just to the side of the stock sending unit. on the inside you run a hose into the tank for the pick up. Then you can use a AN fitting on the outside for a larger fuel line.
Dave "Big Injun" Anderson
[email protected]
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
Old 01-22-2008, 10:02 PM
vertbird's Avatar
vertbird vertbird is offline
Robb, any plans for ones that fit a 2nd gen F-body by any chance? It sure would solve a lot of problems!
Old 01-22-2008, 10:06 PM
screamingchief's Avatar
Robb,you guys got anything like that planned for the second gen F bodies?
With the second gen F body tank design they're harder to sump than the A bodies are...
Lots of F body guys would rejoice at that being available I'm sure!
Damn,,,vertbird beat me to the draw,,,took too long typing mine...
This space for rent...
Old 01-22-2008, 10:13 PM
RobbMc's Avatar
Thanks guys. Like most of the products we sell, it was something I wanted for one of my cars but couldn't find so we just made one. Whenever this happens, we always think "I wonder if we could sell these?"
Our six valve fuel pumps came about because I couldn't find a decent mechanical fuel pump for my AMX. Our starters because the offset gear reduced starters often came closer to the headers on my cars than the stock starter. Our bellhousing alignment dowels because trying to align a bellhousing with the other brands made me invent new cuss words. Our regulator because it seemed to me a person shouldn't have to buy another regulator if he decided to convert from a dead-head system to a return system (or visa-versa). Our polished aluminum swivel thermostat housings because no one was making them for my AMX, my 442 or for my GS455.
And our prefilters because the Mallory cannister type hang down too far and can't handle alcohol.
Old 01-22-2008, 10:18 PM
RobbMc's Avatar
If the 68-72 A-body sending units sell well we will add other applications. Which application we do next will depend on which application we get the most requests for. So far we have three requests for earlier A-bodies and two for second gen F-bodies.
Old 01-22-2008, 10:26 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I`ll be in line for the A body unit. Any price yet?
Old 01-22-2008, 10:45 PM
DeWayne DeWayne is offline
VOTE for second gen F-bodies
Old 01-22-2008, 11:05 PM
RobbMc's Avatar
The 68-72 A-body units will be $139.
Old 01-22-2008, 11:09 PM
71firebird400's Avatar
71firebird400 71firebird400 is offline
Another vote for second gen F-Body!
Old 01-22-2008, 11:27 PM
Matador-IV's Avatar
Matador-IV Matador-IV is offline
Robb,
Is the pickup going to angle towards the back of the tank like a stock unit, or straight down like the picture?
Old 01-22-2008, 11:38 PM
RobbMc's Avatar
Originally Posted by Matador-IV
Robb,
Straight down.
The stock ones only angle back about an inch. And they only do that so the "sock" will sit flat on the bottom rather than get bunched up during installation.
It was fairly tough to design a 1/2" pickup with a 1/2" return AND still have a sending unit AND still get it all to fit in the stock hole in the tank. Making the pickup tube longer and bending it towards the back of the tank made it impossible to install.
Just like when using a stock sending unit, we recommend keeping the tank at least half full when drag racing.
Old 01-23-2008, 11:09 AM
younggto younggto is offline
Another vote for early A-body. -Jesse
Old 01-23-2008, 11:22 AM
triathlonx13's Avatar
F-Body vote here !!!
RobbMc - they made more F-Bodies !!! Plus the trend is moving to going F-Body because a availability (just ask Year One and others!)!)
Old 01-23-2008, 12:30 PM
Bigger is Better's Avatar
Bigger is Better Bigger is Better is offline
Rob,
Another vote for the 2nd gen Fbody, I can use it with the pump and regulator I just bought from you!
Johnny
1980 455 TA
Autocross/Hillclimb
Powered by SD Performance
http://youtube.com/watch?v=Xc5rpSGwXlM
Suspension by www.pro-touringf-body.com
Old 01-23-2008, 01:32 PM
janderson's Avatar
janderson janderson is offline
2nd Gen F-body...put me down for two.
Old 01-23-2008, 01:38 PM
BILTIT's Avatar
BILTIT BILTIT is offline
What about us X-bodies? I assume it would be the same as a first gen. F-body.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 01-23-2008, 05:51 PM
goatman65's Avatar
Price is right. Ill take one for early A-body,1965.
