Old 02-04-2008, 04:49 PM
trv24217 trv24217 is offline
Default 67 GTO california rochester carb 7037262.
I just got a 67 GTO that is a california car, complete with AIR emission system still intact. The car has the Rochester cali carb 7037262. I would like to replace the carb with a after market carb that will just drop on and bolt up to the existing manifold and plumbing. The old rochester is spilling fuel onto the manifold, wont idle and runs like crap..My long term idea for restoration may be to keep the AIR system intact to keep the car correct or to ditch it. Until then I just want it to run good for a few years until I decide what restoration route I will go. Any aftermarket carb suggestions would be appreciated.
Tom.
Old 02-04-2008, 06:01 PM
6704gto's Avatar
6704gto 6704gto is offline
you can either rebuild ur carb thats on the car now or just get a other 2 barrel carb to put on it.if it was me i would keep the air equipment on the car
Old 02-04-2008, 07:00 PM
GTOGreg's Avatar
GTOGreg GTOGreg is offline
In case you were considering selling it, I think 6D7GTO was looking for one of these carbs, or maybe it was the Federal version?
1967 GTO
Tyrol Blue/Blk Cordova
400, TKO-600, 8.2 Posi w/3.55
400 + .020, decked to .005
SD Performance 240+CFM 670 heads
RARE HO/RA manifolds
RARE 2.5" Exhaust (18" Magnaflows)
SD "Stump Puller" HR cam (230/236, 112LSA, 107.5 ICL)
PRW stainless 1.52 roller rockers
Forged TRW slugs
SCAT H-Beam forged rods
Old 02-04-2008, 08:03 PM
I think i'll hang onto the carb. This car lived in Salinas for 37 years then trucked to the east coast. It is all complete and unmolested. Hope all is well in Fremont, I was a resident of the bay area myself in 84,85 AND 86. Hayward, San Mateo, South SF ... I sure did like weekends at Baylands Raceway and KFOG on the radio.
"My car is from Fremont, now it lives one hour from Baltimore"
Old 02-04-2008, 09:32 PM
sixxty7's Avatar
sixxty7 sixxty7 is offline
you might want to think about sending that carb to cliff for a rebuild. had him do mine, car runs great. now, i don't even think even think about an aftermarket. just my 2 cents....
Old 02-05-2008, 01:24 AM
Vmax's Avatar
Vmax Vmax is offline
I went though the same thing with my 67. Q-jet was worn out. I bought a new holley spread bore 650 which ran and idled OK but it was seriously lacking in power no matter how I jetted it. At the same time I sent my original Q-jet back to Cliff. The Q-jet is now back on and the car runs big time. The power is back! I can tell by how hard the
T400 barks the 235-60s tires going to second gear. Great job by Cliff.
Vmax
Vmax
67 GTO Hardtop, 400HO, Bench Seat Column Auto, AM/FM.
Old 02-05-2008, 06:12 AM
Thanks everyone, How do I contact Cliff the carb man...
Old 02-05-2008, 02:46 PM
Old Goat 67's Avatar
http://forums.maxperformanceinc.com/...r.php?u=140049
Old 02-06-2008, 02:38 AM
vidguy's Avatar
vidguy vidguy is offline
Default Cliffs website
www.Cliffshighperformance.com
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 02-06-2008, 04:59 AM
Thanks I'll give them a call.
Tom
Old 02-06-2008, 11:19 AM
GTOGreg's Avatar
Yep, another vote for Cliff. He's done two for me and I've been very happy with the results.
1967 GTO
Forged TRW slugs
Old 02-06-2008, 07:31 PM
carbking's Avatar
carbking carbking is offline
Whether you have Cliff rebuild your original, or go with an A/M carb; remember that as long as you retain the original 1967 intake manifold, that stainless steel baffle sitting under the carb is REQUIRED!
While they have been reproduced, the original may normally be saved, if care is taken when the carb is removed.
Jon.
Old 02-07-2008, 05:22 AM
Thanks Jon,
I spoke to cliff yesterday he provided very good info. His wait is 6 to 8 months so until then I need to find a temporary carb. I am looking for a temp rochester so that it hooks up to exixting setup. Do you know of any aftermarket carb that will be a ok temp replacement.
As far as the steel baffle under tha carb is there any good way to remove the old carb with out damage to the baffle.
Tom.
Old 02-08-2008, 01:19 AM
Vmax's Avatar
Pull the carb, drill and tap both exhaust passages in the intake manifold. Screw in two brass pipe plugs and you will be happy. Ask Cliff about this mod. I have had no problem with my choke and the carb runs much cooler and I think it is a bit more responsive when the car is hot. With this mod you do not have to replace the stainless plate. It can be reversed by removing the plugs if you don't like it.
Vmax
