Old 02-15-2008, 10:20 PM
Red69Goat Red69Goat is offline
I'm thinking about going a similar route with the rebuild of my stock YS-code so I'm anxious to hear feedback from others. I've been told anything over about 9.5:1 compression will not run well on modern pump gas, but I'm by no means an expert on this subject. You might consider having the pistons dished to get the compression down from the stock 10.75:1.
69 Grand Prix Model J, Cameo White/Black top, 400-350HP, automatic, unrestored 53K-mile original paint
69 GTO HT, Matador Red/Red interior, 400-350HP, automatic, Hideaways, AC, PS, PDB, original numbers matching work in progress
Old 02-15-2008, 11:08 PM
techteacher5561's Avatar
techteacher5561 techteacher5561 is offline
Default couple 5 cents worth
Stock intake will work fine, maybe massage the divder a'la Jim hands book, which if you haven't picked up you should. The Q jet will work great if rebuilt well. If you're willing and have some experience you can do a pretty god job following Cliff Ruggles tips in his book- yeah this is the other "if you haven't picked up you should" tip.
16 heads are good, simple porting and gasket match will help a bit. RA manifolds beat out the stock Logs and may fit easier than headers. More stock looking too.
I just looked into a cam for my new motor build and Butlers suggested a XE268 for my "stock" 428 rebuild. Specs are a cross between the RA III and IV.
But your situation maybe different than mine, I've got a M20 tranny which is more forgiving then a AT
Have you or are you joinign the Rochester POCI group?
I'm in the Syracuse Six Nations POCI club and theres usually good people there and lots of advice/ experience. Pontiac Jack on here (PY) is out your way (Phelps).
Several guys from Roch came to Syr for our Spring show and several guys from here when to Webster for the Roch show. I hope to do that to this year.
My motor should be done this week but not sure when it will get installed. Sometime before the first ESTA test and tune in April I hope
Howard
1968 Lemans Convertible, Burgundy/Parchment 1968 428YH motor, ported#16 heads, Crosswinds intake, Cliff Ruggle built 750 cfm Qjet, Comp Cams XE268-110 lobe sep. Duration at .050" lift 224/230, M20, 3:23 rear, PS, PB. Best time with need mods: 14.0071 in the 1/4 mile at 100.00 mph
Old 02-16-2008, 10:06 AM
JKGTO's Avatar
JKGTO JKGTO is offline
Is the block fresh and 30 over or will it need bored to that? If it needs bored I would go with a stroker crank kit for more cubes and it will look stock. You can drop the compression so its more drive able also. Definately get the Qjet calibrated for your combination. Bigger exhaust like 2.5" mandrel bent pipes with RA manifolds will help a bunch. Get some new rods too as the old ones are 40 years old. Cam selection is a personal choice but bigger isnt always better here. Cam depends on compression, cubes, rear gear, and tire size to really figure out a good choice. More cubes can tolerate a bigger cam. Put a shift kit in your trans and get a good converter if budget allows. The 3.55 gear is a good all around gear. Stock fuel pump should be fine. Problem may be pickup tube in tank as well as fuel lines. Could have dirt and crap clogging things up. A lot of choices to make before you spend the cash. Good luck. Jim
74 LEMANS GT 350 4SPD MAROON
Old 02-17-2008, 07:37 PM
ebgto ebgto is offline
Default Thanks for the info, keep it coming!
Thanks for the feedback! I'll be getting Jim Hand's book, that should help.
I think the car has always had shift kit in it, but I never really cared for it, due to the drawn out shifts. Maybe it was just poor tuning or vacuum. Any recommendations on a shift kit and set up, for a mild cruising ride, but still have firm shifts? Any torque converter worth considering over stock?
I'll go with the 2.5" exhaust and RA manifolds. Rather do it now than later.
I purchased the engine and the rebuild was already started, so it is already 30 over. I was going to stick with the original crank. My shop is checking everything over first, so I'll see what they think of the rods.
Once I get the info back, I'll let you guys know how it is progressing. Keep the info coming, it is a great help after being away from my GTOs for awhile
I'm not in the Rochester POCI but knew some of the members from the 80's when I was banging around in my 67. I may just join once the 68 is running decent again. I'll be up at the Nationals (with or without the 68).
'67 GTO Convertible - a couple extra HP, On the road!
'68 GTO Convertible - in frame off stage
'67 GTO Hdtp, HO 4 speed - next
Old 02-20-2008, 07:13 PM
Red Coupe's Avatar
Red Coupe Red Coupe is offline
Good advice in this thread. Stroker is a good low cost option. There are guys (Ed Curtiss is one) who will get you a custom ground cam based on your car, its weight, the CI of your motor, trans, gearing, and RPM where you want to make power. Cost is very competitive with "off the shelf" cams, so well worth the cost.
My basic advice is to decide what you want the car to be an stick to the plan. If you want the fastest set of wheels in town, you better have a thick wallet, and plan for every dollar spent on the motor to spend 2 on trans, rear end, suspension, to make the car both safe and fast.
Another option may be to toss a 75 shot on the car and call it a day. Others more knowledgeable about stock Pontiac motor will need to chime in here.
Done rambleing now!
