Old 02-24-2008, 12:02 AM
roysgoats roysgoats is offline
Great idea for a TATA forum! Here is my question. I have a 79 TATA that i am having a little paintwork done on it and am replacing some decals and pinstripes. I order pinstripe roll from Phoenix graphics and noticed the black portion is wider than the red. On my car most of the pinstrioing is the same thickness. Is it correct to use the pinstripes with the Black thicker than the red on all areas of the car? If this is the case then I am guessing that when my car was painted in the past someone used rolls of red and black that were incorrect. Thanks in advance for your repsonse.
Old 02-24-2008, 12:30 AM
165th's Avatar
165th 165th is offline
2manyT/A's this is a Norwood car. It has Silver Seal worm gears on all 4 heater hose connections. The radiator hoses of course are tower clamps on all 4, with the upper radiator clamp clocked at 2pm (if you facing the car).
Here's a pic of the rust, I mean brake booster and bracket. The red smear on the booster is a paint daub I think, but it's not your typical enamel, it's more of a stain so to speak. There is also a very small blue paint daub barely visible in one picture. The paper sticker on the wiring harness to the proportioner is a W.
The carb picture is great. The part number on the vacuum bracket, and the inspecton mark 'N' and ' - ' on the butterfly is unbelievable considering fuel and fumes pass this way.
Roysgoats, the stripes are different thicknesses. The black is approximately .25" and the red is .13". I'd be curious to know what thickness the Phoenix Graphix stripes are?
Quicksilver, that's a great question about the pace cars. I thought they would have been geared high for the track? Hopefully someone will chime in.
'Restoring' this car will be a lot of work. I'm going to be refreshing all of the parts, but without repainting, replating or replacing. It should look the same when done just neat and tidy. It's tedious and meticulous work as I'm already finding out, but very rewarding.
Name:	stripe details.jpg
ID:	123567   Click image for larger version
Name:	brake MC and booster sm.jpg
ID:	123565   Click image for larger version
Name:	brake booster details sm.jpg
ID:	123564   Click image for larger version
Name:	carb details and stickers pass side sm.jpg
