Old 03-15-2008, 09:53 AM
BDHABT's Avatar
BDHABT BDHABT is offline
I used the 246/253 duration cam in my 455 way back when.
That was an awesome grind.
Went 12.01 time after time.
Heres a quick breakdown:
Car weighed 3750 at the time.
455 .030 TRWs.
No 13 heads,unported.Just a valve job.
Stock T-2 intake.
Holley 850.
1.75 Heddman headers.
Comp Roller tip rockers.
Torque Tech 3" exhaust with tailpipes.
Generic TCI 3500 conveter.
3.89 gears.
Cam was also advanced 4 degrees.
Gave alot of Mustangs the whooping;as that cam was very streetable.I drove that thing everywhere.
Mark.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
Old 03-15-2008, 10:00 AM
goatasaurus rex's Avatar
goatasaurus rex goatasaurus rex is offline
that's a deal twister!!! who's buying the beer??? smitty???
69 GTO 11:[email protected] all balls no bottle
406 d-port iron heads 3700lbs all steel
Old 02-20-2009, 07:15 AM
Motor Daddy Motor Daddy is offline
What does Pete mean when he says, "Closing the lobe separation angle (paradoxically, spreading the lobes apart) increases the overlap but also closes the intake valve sooner, resulting in higher cylinder pressure?"
Closing the lobe separation angle spreads the lobes apart???
Old 02-20-2009, 09:44 AM
gtofreek's Avatar
gtofreek gtofreek is offline
Yeah, I also would think it means tightening them up, no spreading them apart.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 03-15-2008, 10:17 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
455 .030 TRWs.
Stock T-2 intake.
Holley 850.
3.89 gears.
Mark.
That is a killer grind. BTW, Your location says your with my wife? You poor bastard.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Closed Thread
