This one is pretty darn SQUEAKY!
http://cgi.ebay.com/ebaymotors/ws/eB...213966578&rd=1 Other than the radio,wheels/tires, it looks "unmolested'. I'm guessing this one is a "poser" WS6 & W72. Wheels are obviously refinished replacements & the A/C compressor is doing a pretty good job of hiding the P/S valve cover. I don't see any foam on the fuel line. It's also likely had a waterpump replacement (the factory ones never lasted much longer than the warranty) I'm surprised it's only bid to 15K. Sounds like he wants 25K,which I think is a GOOD DEAL,if car is ACTUALLY as nice as it appears to be. |
The bodyside moldings look wrong.
Randy W 1975 Firebird third owner. 1980 Grand Am/black/beaurdeaux/45000 mile original owner.(Now belongs to Iowapub.) '67 Impala SS (sold) |
ANY bodyside moldings on 2nd gen Birds looks BAD/WRONG. Those are likely a dealer install. |
The numbers on the odometer appear to be uneven. That would be expected if it had just turned 20,000. Usually the numbers would even out in about 20 miles past the flip. I alway thought that uneven numbers was an indication of tampering.
Alan Tomorrow is often the busiest day of the week. |
It's definitely NOT a W72. Has the L78 air cleaner base, no foam fuel line insulator. Nice looking car though.
Jon O'Neall 1977 Y81 T/A W72-400/Auto "Trans Am! What's your pleasure?" |
Body side molding looks EXACTLY like what my 78 came with from the factory.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
If its not a W72 then it should not have the shaker callouts. That makes me wonder about the paint being original.
My '79 had factory side moldings and they were finished better and were below the body crease not above it.
My first clue on this one was that the shaker decals look slightly out of position.(non factory installed?) |
I own a couple '78 TA's now and both have body side molding from the factory. The moldings on the car in the ebay add appear original. Also, in '78 I bought a TA without the W72 (I was told the factory wasn't making anymore W72 with automatic when I ordered mine) option. The dealer said I could just buy the T/A 6.6 decals and add them myself, giving it the appearance of a W72. I'm guessing that is the case here too.
78 Trans Am
Went back & had another good look at those moldings and I think that even though they MAY look like OEM moldings,they really DO look kind of FRESH.
They are are just a bit TOO NEW looking for being 30 years old. That chrome vinyl edge tends to fade with age regardless of UV exposure. I'll bet they were recently installed by the seller to hide some minor door dings/fender scrapes in the body line. Would be nice if we could see the build sheet. That would tell the story. You might want to scroll down to the bottom of the auction pics & read the LAST (top) question & answer that was posted. I near "bust a nut" laughing over that one. The seller OBVIOUSLY has a sense of humor! |
Also it looks like the E brake rubber is not on properly(bottom right)
JIM |
I will take another look at the body moldings on my TA's. Mine are very low mileage cars and I thought my moldings looked pretty good with no fading.
I know for a fact that my roof drip moldings faded on each of my TA's. Even though the cars have been stored, they are faded yellow. I also noticed the E brake rubber pad corner not properly on and the answer to the question left from the bidder... That was worth a good laugh!
78 Trans Am
One thing for sure, you don't see those "hush" panels still under the dash anymore!
The silver centers were oxidized, so I ended up putting on aftermarket moulding to hide the holes that were drilled in. 68RT
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
I parted out a 73 Esprit a number of years ago & the body side moldings were installed with clips on studs (the same style studs that hold the window molding clips,rocker triim & belt reveal moldings on)
They were ALSO an aluminum extrusion with a push in vinyl rub strip. I figure the MAJORITY of these bodyside moldings were DEALER & NOT factory installed. My 78 came with metal,NOT plastic roofdrip moldings. I've seen them either way. I wonder what determined which ones went on a given car? |
Boy, you guys are tough!!
78 White T/A, Carmine interior, Fisher T-tops, WS-6 package, 3.08 gears, a/c, rear discs. Original 403 with 300,000 miles replaced by new Pontiac 455 (roller everything, 6x-4 heads, Performer manifold, Hooker Headers, Hughes converter, Cliff's Q-jet) - I only get 12 mpg! |
