Old 04-25-2008, 11:13 PM
superblue72 superblue72 is offline
Default coils are a PIA
has anybody ever changed these on their own? compared to some of the springs i am used to seeing, they are huge! i can't seem to compress them with my DIY spring compressor. should i take this job to the shop?
Old 04-26-2008, 07:05 AM
AGTO8U's Avatar
AGTO8U AGTO8U is offline
Use jackstands to get the front end up high enough to pivot the lower control arms down to get the old coils out. With a floor jack under the lower control arm, loosen the nut on the ball joint part way and hammer on the back of the spindle next to it until the ball joint "pops" loose. Remove the nut completely then and proceed lowering the control arm with the floor jack. The spring should drop out. I had to loosen the brake back plate, and pry slightly to clear the lower control arm. Put the new coil in the socket and angling it a bit resting the spring on the lower control arm. You may have to hold the coil with your foot while raising the control arm in place with a floor jack. Its easier to use a spring compressor, and have a helper hold it in place but can be done without.
Old 04-26-2008, 09:24 AM
stu72's Avatar
stu72 stu72 is offline
If you use the floor jack to take these out take the time and put a chain through the coil and around the frame some how. This way if the pop out they will take your head with thim.
Old 04-27-2008, 06:56 PM
i just got done installing coils and shocks on the front passenger side. I'm not even going to bother with the other one - too much hassle.
I did notice something different, the new springs raise the height by a few inches. Is that normal? Does it have to be broken in?
Old 04-27-2008, 07:14 PM
AGTO8U's Avatar
Front end will settle a little, usually less than an inch from initial installation. The front coils I replaced on a 73 Ventura a few weeks ago measure 27 1/4" to the wheel well lip with 215-70-14 tires.
Old 04-27-2008, 09:48 PM
thanks for the help AGT08u
now i have to figure out why one of my back air shocks is not getting air. soo many problems...
Old 04-27-2008, 10:57 PM
SergeF SergeF is offline
Superblue,
Did you install springs in the right position? They are not too bad to do once you do it couple of times.
Old 04-28-2008, 02:00 AM
hey serge, what is the right position?
i'm sure i installed it right, it doesn't seem to have any gap on the bottom. it's a lot of work compared to some of the other struts i've installed. getting the control arm bolts on the ventura to line back up wasn't easy.
Old 04-28-2008, 08:44 AM
Rob B's Avatar
Rob B Rob B is offline
Why risk the whole jack and chain crap when you can either rent a spring compressor or just go buy one. There not that expensive and the last thing you need to do is have on fly out, damage the car, and/or drill you or someone standing by you!. Makes no sense.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 04-28-2008, 12:45 PM
engineer engineer is offline
actually the internal spring compressor with the claw hooks is very difficult to remove once the compressed springs are installed. Also, it is hard to figure where to position it at first to get enough compression so the spring can be easily installed. Better to find the one using the heavy threaded shaft and the washer type setup which are not common and typically not available to rent.
Old 04-28-2008, 11:10 PM
Ok, so now both of them are installed and these spicer springs have raised the front of the car by almost 2 inches. I really hope they break in and settle a bit.
Old 04-28-2008, 11:32 PM
BILTIT's Avatar
BILTIT BILTIT is offline
Did you tighten the a-arm bolts with the weight of the car on the springs?
You will need to leave them loose and have the car on the ground on the wheels then bounce on the bumper a few times to get them to rest in a natural postion then tighten up all suspension components other wise they hang up and bind and give you the height issue you have now.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 04-28-2008, 11:44 PM
do you think this is too high?
Old 04-29-2008, 12:12 AM
BILTIT's Avatar
yes, what tire size?
Here is mine sitting and lifting while i launch.
235/60-15 in front on a 15x6? rim i think.
ID:	130931   Click image for larger version
Derek B.
Old 04-29-2008, 12:16 AM
BILTIT's Avatar
Be sure the coils sit in there recess on top and bottom, they can be tricky.
Derek B.
Old 04-30-2008, 12:52 AM
AGTO8U's Avatar
Yours looks high in the picture, but should drop down after you drive it around. Heres a picture of mine after approximately 1 month.
Old 05-01-2008, 01:05 AM
yeah, i think put in the springs the wrong way. it still had a gap on the bottom. i compared with the one i worked on and the one my mechanic worked on, theirs were a inch shorter.
Old 05-01-2008, 04:27 PM
hey biltit, what shocks do you have on the rear?
Old 05-01-2008, 06:23 PM
BILTIT's Avatar
Factory replacements from canadian tire (delco's?), i have shock extensions put in (4 or 6''? I cannot remember).
Derek B.
