Old 05-11-2008, 09:24 AM
andrewb70's Avatar
andrewb70 andrewb70 is offline
Originally Posted by Z Code 400
Andrew,
Let me caution you about the use of galvanized fittings to conduct pressure tests on the brake system. These parts are full of imperfections and are not rated for much over 45 psi safely.
I have seen a number of those fittings fail on the shop compressed air system at a low 165-170 psi.
Best of luck and do be careful...Robert
Thanks for the tip Robert. I got all the parts from a local hydraulic supply house, and I just assumed it would be safe since they pieced it all together. I am done testing for now. If I do any more testing in the future I will replace what I have now with some quality steel fittings and a short piece of Teflon hydraulic hose.
Andrew
