Old 05-14-2008, 04:24 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
Originally Posted by Mr. P-Body
David,
"Your" 98 octane is measured differently than ours. It's more comparable to "our" 93. I agree, a small "dish" in the piston to get the compression down to 9.5:1 is called for.
While that cam is okay, it's an old "generi-grind". We (CVMS) use Comp XE grinds. Your combination is just right for XE262H. If you stay with the RPM intake, XE268H might even work a little better, but the small valves will hurt top-end power. I agree with 68lemans, a Q-Jet and the factory intake are more in line with your goals.
I would also invest in a set of aftermarket connecting rods. The stock cast rods, while good for stockers, aren't tough enough for the rigors of road racing. We use Eagles, but there are others out there for a little less money. Avoid the ones that are a LOT less...
Jim
Jim, Great comments as always. I agree with you on the comp cam. My build was a "budget" build, so I opted for the melling cam/lifter package which was CHEAP! Wynter, it sounds like a chevy guy spec'd out your combo...... Take Jim's advice, he builds some MEAN motors and he is a hell of a guy.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
