all sounds like good advice, will look into it,thanks. well took the first step and ordered that jim hands pontiac book
![]() and also as im here and got your attention. what do standard pistons in a 400 1970 look like, i only ask as mine look very new, clearly havent been in there long, i know the guy before me did a basic rebuild but as this is my first 400 i dont know what the pistons as standard look like. mine have 4 valve relifes in them and have STD stamped on all of them, are these standar or aftermarket? |
I don't remember if GM stamped STD on the factory slugs, but if if you see L2262F stamped on them you're looking at a set of TRW forged pistons. These used to be about $200/set, but have risen in price to about $340/set now.
If the the bore has less than .001" taper from bottom to top, you could reuse the pistons to save money. I would only recommend cast pistons for a bone stock application- like the factory rods, they will only withstand standard loading. If you're planning to do any type of racing, use forged pistons and rods- the factory parts will fail in extended high rpm use. Geno |
