#101
Another renowned 200R4 performance innovator and builder is Mike Kurtz here in the Houston area. He was building these trannys for the turbo buick guys years ago. His transmissions can handle up to 1200hp.
His number is toll free 1-866-869-8120 and in Richmond,Tx. 281-633-8155
Home of WFO Hyperformance Shaker induction. |
#102
![]() "Life is one big smokey burnout after another." -- me |
#103
Larry, is that Century Transmission?
Ken, I'll give you $1,500 for it right now.
12.84 @ 106.89 with street radials. 12.63 @ 108.39 on drag radials. |
#104
That's an old filing cabinet in the pic. Core included means no core charge, no exchange needed. I will deduct the core price if someone provides an exchange. It is $75 on a 200-4R. No converter included. I recommend Edge or PTC for a good converter, and I have a couple of sources for budget mild street converters. |
#105
'79 T/A 6.6 4-sp, 3.23 , 463" E-heads, 252/262 hyd roller, TII, Holley 830, 8.384 @ 93.86 - 1/8, 12.5 @ 116 - 1/4, 2.035 60', 3800 lbs. w/o driver |
#107
Is the 200r4 a direct bolt on replacement for a TH350 on a second gen firebird?
I am in the New York area, any known good tranny builders around here?
Can do the talk, can't do the walk......therefore need deep pockets ![]() Injection is nice but I rather be blown If you got it flaunt it, if not fake it (Snoopy) Original 1977 Firebird / Welded tube frame connectors TH350 with shift kit / 400 bored/stroked to 455 by PDude OCD=Waxing and polishing your oil filter SICK=wetsanding your exhaust pipe |
#108
You can use the same driveshaft, the TV cable must be set properly.
I used BTO level III 200r4 , TV kit, and their convertor behind my 301 for 2yrs, no problems. As soon as I get my new 428 straightened that will also go with their 2600 rpm convertor. I will post how that goes!! |
#109
Birdman, you have to move the tranny crossmember back a little. Nowadays there is a crossmember available to bolt right in though.
Your original tranny mount is fine, just use the metric bolts to fasten it to the tranny. The cooling lines even hook up, but you have to tweak them a little (rebend here and there by hand to get the new angle as the exact connection points are not the same.) Speedo cable hooks right up and the tranny of course bolts to the "five families". I have only ever seen one 200-4R with a BOP only pattern. I believe it was a first year edition too (1981?) This is the easiest trans upgrade if you are replacing a 350 short tail. We have four of them in our fleet now. Not a single problem or issue.
"Objects in mirror are closer than they appear"
#110
Thanks Overkill, however when I installed my 3.73 rear, I could not get the correct drive/driven gear for the speedo so I had a converter box made. When I get (or have it built) the 200R4 I just tell them what rear ratio I have and get it with the correct setup?
Do you know any fairly reputable tranny shops in the New York area? ( I am around 80 miles N/W from NYC)
#111
I use a GN governor always in my 200-4R's. If I was running a 3.73 gear like you I would run an 86-88 Monte SS driven gear (I forget the color off hand). A 3.42 rear then I run the Buick GN driven gear, and 3.23 I run the Turbo T/A (1989) driven gear.
Given your locale, I would go to Level 10 in North Jersey. Only a hop, skip and jump from the big city. Just don't make the same mistake I made one time by telling them I wanted number 11 on a scale of 1 to 10! Holy crap, the rear axle would literally jump off the pavement when it shifted to second! Had to tone it down a bit after the novelty wore off (about a day and a half later!)
