Man I am alomost sure that he said 212/225 when I was watching the show. Oh well, they will show it again about 50 times anyway.
lmao! i cringed when i saw that, chebby side inlet and all. at an old job i used to sell "rebuilt" q-jets, and i agree with cliff r, the box they come in has more value than what's inside.
costs too much |
i did not see the show and i am not sure what all went into the build BUT my "budget 400 build" with 96cc heads will cost me about 2500.00 if you dont include the cost of the motor to begin with. it should be a little better performer than that one with about 8.5CR and a little bigger cam.......
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-3:55 Moser rear-Dougs Headers.... |
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
The one thing i caught during the episode on HP was that the heads had press in studs and when they came out of the machine shop, BAM, screw in studs. No mention of choosing a head with screw in studs to save money at the machine shop. Pontiac made tons of them, and they aren't that hard to find. That's TV for ya.
The engine they grabbed out of the junk yard was a basic 400 2-bbl engine with 4x-8 heads I believe. They used the same components that came on the engine. No build-up from a swap meet deal. The swap to screw-in studs was probably recommended by the machine shop if they found some "tall studs".
The engine looks like a sludge bucket (oil never changed). Tom V.
The point is that your engine is a high compression engine, which is what that cam was designed for. It doesn't work all that great in low compression engines, there are many better choices for engines with low compression ratios.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
Too bad you can't watch their episodes on the net.
they gave up on the 4x heads they had and got a set of 6x's from butler perf with screw in studs and all rebuilt. its sad they consider the pontiac 400 for their no budget project if they put just a few well chosen pieces into the mix it would have ran way better and there fore worth making a tv show about.IMO
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines! 2006 silvy Z71 4X4,383 LS 600+hp NA Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-} |
Hopefully HP TV will do a follow-up segment and build a higher hp build up of a 400- a 400/462 stroker would be nice. And maybe next time they will do some homework and not look like a bunch of Chevy guys building a Pontiac motor
. It was still nice to see a Pontiac being featured though.Geno |
I think it's sort of refreshing to see a budget build (regardless of engine make) on these type of shows.
Most of them will show you a boatload of aftermarket goodies (that was donated by sponsers for the advertising) that cost a boatload of money. Nonchalantly; "Oh yeah, we dropped a 572 with a blower in there". Something the average Joe in his garage will probably never afford nor opt for a street car. Personally I'd like to see an engine challenge that had a cap on what is spent. Something low, like $2K to $3K, tops.
The joker in the deck keeps sending me his card. Smiling friendly, he takes me in. Then breaks my back in a game I can't win. |
D port Iron heads, cast crank, cast rods, any personally known internal trick mods allowed, most dyno power wins the Big Chief Iron Head award. Auction off the engines for charity? Get some sponsers like PY, and any other Pontiac suppliers. |
How did you arrive at that figure? I'm not real well-versed on the pre '67 engines, but it is my understanding that the only 389s to come from the factory with an 068 cam would have been high output 4-bbl or tripower engines, which all would have been rated at over 10:1 compression. This is the case for '67 and later engines; only the 400 or 428 HO and Ram Air engines with 10.25:1 or better got the 068 cam, until the low compression 455 HO of '71, but a 455 is a different animal than a 389/400 and can make use of much larger cam. In any case, assuming your true compression ratio is at 9.5:1, that isn't what would be considered "low" compression. Not exactly "high" either, but about the maximum recommended for pump gas with a stock type cam. The 400 being discussed in this thread originally, with 98cc heads, would be right about 8:1. Lower RPM power begins to fall off rather dramatically below 9:1 compression unless changes are made to the combination (smaller cam, earlier intake closing events) to compensate, which in turn hinders higher RPM power. Since I don't know your entire combination I can't comment on what cam *might* work better for you, but it sounds like you are at the threshold where the 068 cam works as the factory engineers intended it. There is a reason the 068 was not used in anything smaller than a 455 after 1970. The cam used in this engine was not an 068 duplicate, and in fact would work better in a lower compression engine than the 068, but it is still not the best choice for an engine with an 8:1 CR. A cam like the Comp XE262, which is specifically designed to boost cylinder pressure in lower compression engines would have been a much better choice.
I don't think the well-known Pontiac builders would be interested in trying to get a stock-rod Pontiac motor to make power, because they already know most of the cast iron internals are reaching the end of their life and will fail when pushed to the limit. I also doubt they want that liability in their motors, when they what they sell is performance. Geno |
My 15 year old son and I watched that episode and surprizingly he said "Dad I could build a better engine than that", of course I couldn't stop laughing(confirming he has been actually paying attention while helping me in the shop).
#38
I've run tons of stock rod (prep'd) and stock crank engines well past the 500hp mark, because for the longest time, there wasn't anything else available. They lived, and longer than I thought they would!
I saw that segment too, was totally disappointed actually. My daughter trashed the steel wool thing! I wasn't even watching at that moment! I don't really care that they didn't do justice to Pontiac power, and actually prefer more people sticking to 'other' brands. Leaves the parts for true Pontiac people! Since we've heard a couple 'dream posts', wouldn't a show, or even segment, dedicated to Pontiacs be nice? If it weren't for these defective lottery tickets I've been getting lately, I do that show...
#39
HP TV even had Butler prep theirs for that build. |
#40
I wouldn't worry about using stock rods in a 400 up to 6000rpm, or 500 or so HP. Then on the other hand if it was going to be a stroker, or 455, the forged rods would be a good idea. The longer stroke is what is hard on the stock rods.
