Old 06-18-2008, 12:15 AM
andrewb70's Avatar
andrewb70 andrewb70 is offline
Yesterday and today were two very exciting days. Monday morning I showed by to Schwartz Extreme Performance in Crystal Lake, Illinois. Jeff Schwartz and his crew were waiting for me so they can begin to adapt my shaker scoop to the new engine. One of Jeff's fabricators, Ken, was responsible for the project.
After looking things over and mocking up my old shaker base it as decided that a whole new base would need to be made. So Ken rolled a new base and bottom.
The only part of my old base that was reused was the upper lip that attached to the shaker top.
Ken also fabricated another piece that was welded to the inside of the base and held the air filter element. I picked this filter element because it is as large as the base will allow. The filter is also rather thick which gives it more area for better flow. It also happened to be in stock at the local AutoZone, which means I can get a replacement just about anywhere.
Another one of Jeff's fabricators, Kyle, helped out with the TIG welding of the 4" pipe that connected the base and the throttle body.
Today everything was starting to take shape. The MAF was mounted inside the pipe towards the the top, just after the rubber coupler.
Tomorrow morning I am heading out to Colorado. I will be stopping in Lincoln, NE to visit my friend Brian. Brian did the body and paint on my GTO. We will smooth out all the welds on the base and paint everything a semi-gloss black. Thanks again to the crew at Schwartz Extreme Performance for a job well done!
Andrew
