WELCOME!
Old 07-16-2008, 12:46 PM
Dick Boneske's Avatar
Default 2004 GTO Door Lock Actuator Failure
My '04 has 6,772 miles on it with NO problems except failure of the driver's side power door lock. It can be operated manually, but not electrically. This is a common problem with '04-'06 GTO's. Has anyone been successful in getting GM to warranty replacement of the door lock actuator? If not, how much does a dealer charge to replace the actuator and how much does GM charge for a replacement part?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 07-16-2008, 02:48 PM
Partial answer to my question: Cost for GM dealer to replace door lock actuator is $293.30. Actuator costs $154.74. Time needed is 1.30 hours. Dealer suggested I call the Pontiac Service toll-free number to plead my case for warranty replacement.
BONESTOCK GOATS
Old 07-28-2008, 07:37 PM
mkturtle mkturtle is offline
Did you take door apart and made sure it is the actuator? I am asking becouse there is a similar problem but the mechanism is at fault.
1975 T/A - sale pending
2006 GTO
Old 07-28-2008, 09:27 PM
Thanks for the response, but I have no interest in taking the door apart on my '04 GTO with 6,777 miles on it. I called Pontiac Service 800 number to let them know I was aware of failure of the power actuators on the '04-'06 GTO's being a common problem. They insist I have the dealer diagnose, which I did today. Yes, the actuator is the problem. Diagnosis is $50 plus $293.30 for parts and labor. They committed to "helping" bear the cost. I'll keep you tuned in.
Good news is---This is the ONLY problem I've had with this '04 GTO. Bad news is---costs too much to fix it and it shouldn't happen on a car with 6,777 miles on it.
BONESTOCK GOATS
Old 07-29-2008, 05:40 PM
Dealer received part today, called me, and replaced the actuator. Final result? ZERO cost. They called it warranty, including the $50diagosis. Sometimes, it pays to pursue a problem like this in a reasonable, insistent way. I saved $343!!!
All you GM-bashers take note!!
BONESTOCK GOATS
Old 08-13-2008, 10:17 PM
Dan_e's Avatar
Dan_e Dan_e is offline
Ordered an actuator today, will post up my results after I do the swap.
04 GTO, W40, M6
510 rwhp
Mods
My FQuick Page
Featured Vendors
Advertising Info
