Old 07-12-2008, 07:07 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Default Another new best...
Last weekend running my car at a small 1/8th mile track near here I ended up losing my 2nd gear "pull" and am assuming my clutch pack went bad since the car would go into 2nd, drive in 2nd, but when I had the foot lbs poured to it it would just hit the rv limiter and start banging off of it... So I just laoded up and went home.
I worked all week changing the trans to another T-400 Manual VB trans I had and went to Tulsa's Nostalgia drags today (nothing newer than 72) and man was it a scorcher! TOO STINKIN HOT - I was getting near heat stroke, my Grandbaby was looking miserable and my wife wasn't doing well either. I entered the 0-10.99 bracket class and they had open time trials for an hour and 1/2 at 11:00 til 12:30...
First pass I went up, burned the tires through all 3 gears and then rolled to the line shifting back to low. I was lined up with a nice Tube chassis Mopar and when the lights came down the car reacted extremely sluggish and seemed to stay in low way too long and when I shifted up nothing happened whatsoever - no shifts at all I was way back on the Mopar and went to the end of the track and turned around on the pit road and put the car in park and it was still in gear, reverse was the same way - pulling forward so I limped it back down to the ET shack and picked up my 11.45 @ 118 slip and on to the trailer... I got under the car and the shift linkage keeper had come out when I was in 3rd gear in the burnout and since my car is a Manual VB I launched in 3rd and made the whole pass in high gear I hoped I hadn't toasted the trans so I made a clip out of an extra throttle return spring I had and got it back together and back to the line. I got lined up with a really nice tube chassis 68 Camaro, with MONSTER rear tires and an aluminum headed BB with a Dominator, Power glide, and air shifter (he was parked right next to us in the pits) and I thought I am gonna get left far behind again...
The burnout felt good and the line seemed OK but it was HOT, I was about to melt down in my fire jacket and helmet when we got staged. The lights came down and I treed him with an .023 light to his .145, My 60 foot wasn't the greatest but I got a 1.42 to his 1.40 after that he started reeling me in but it wasn't a barn burner I ended up running a 6.35 1/8th mile @ 107.75 to his 6.19 @ 111.01 and my 10.03 @ 132.44 to his 9.74 @ 136.87. When I picked up the slip I was in shock thinking my trans must have been way worse than I thought it was before I changed it This run was in 96 degree temps with 104 heat index on Hoosier 295/65-15 Drag Radials.
A bit later we had another time run and my car did something it has never done before and really bothered me... It shook the tires so bad I thought my teeth were gonna fall out and had a 1.56 60 foot and went 10.33 @ 130.21 but the last about 1000 ft I looked at my fuel pressure and it was only 3 psi and dropped to about 2 psi in the traps and the car was laying down some. On the return road it was still low so i turned it on and off a few times and it climbed back to 7 psi but somehow I also turned off my cooling fan and water pump that are on a switch together and didn't turn it back on all the way to the pits which was BAD because when I finally got to my trailer I could smell anti freeze and I looked at my temp gauge and it was pegged I killed it and turned on the fans and pump and it cooled back down but it got really hot ...
We had one of those big fold out Canopy for shade and a gustnado came through the pits and tore the top off of it and broke 3 of the upper mounting attachments... The canopy next to ours blew onto a beautiful 1958 Vette and scratched it all up so then we had no shade and were just baking so after talking to some people I know and Ken (GTOKen) for awhile. I talked it over with my wife and we were miserable, I had no chance of winning due to traction issues with the DR, and most importantly my Grandbaby was acting really lethargic so we loaded up and came home... I am done racing in the heat this year, If it isn't cool or at night I am staying home
It was neat seeing some of the old cars and talking to a bunch of Pontiac guys... I even steered someone away from using Fulper
1969 GTO, 5.77 @ 121 1/8th mile 3450 lbs...535 with Junk dinosaur Eheads
Faster on nitrous…
Old 07-12-2008, 07:23 PM
goldbird*12.82 goldbird*12.82 is offline
Send a message via AIM to goldbird*12.82
NICE RUN!
Old 07-12-2008, 09:05 PM
issach428's Avatar
issach428 issach428 is offline
freakin awsome! i was going to come out but got stuck mounting my new mallory 250 pump,(its the size of a minny starter) and then re doing have the fuel system. Your going to be in the nines as soon as it cools down a little.
72firebird 3800# 496 316cfm eheads, 11.1:1 compression, custom solid roller, victor 4500 intake port matched, 1050 dominator, continental converter flash 4400 stall. 3.73. 2 inch headers with 3.5 with x to mufflers reduced to 3 inch full exhaust. mallory 250 fuel pump, cal tracs with split monos ..Pump gas 91 octane.
Old 07-13-2008, 12:24 PM
69Goat1's Avatar
Issach I am going to do the Mallory 250 pump as well since mine lost so much pressure through the run. The one I have is a Mallory comp 140 but I am pretty sure it needs to be kitted... I think I have more room to mount mine than you do...
There were a few cool Pontiacs out there yesterday
Faster on nitrous…
Old 07-13-2008, 12:34 PM
455firebird1969's Avatar
Default Nice job...
You got that thing running good, no big dollar parts, just a good running Pontiac, looks great to boot...
Oh yeah, try sitting in the lanes in GA, talk about wanting to die...
I guess its all relative...
Old 07-13-2008, 12:49 PM
Ron H's Avatar
Ron H Ron H is offline
Great Job on picking up nearly .2. WTG.
I swapped to a 250 Holley Volumax and eliminated the Mallory 140 not keeping up. 140's are good to around 125 MPH but after that they have a hard time.
68 Firebird
Are you running with the wind or breaking it?
Old 07-13-2008, 03:30 PM
scott70's Avatar
scott70 scott70 is offline
Nice ET's!! Whats your engine specs,carb and jetting.
Old 07-14-2008, 11:09 PM
69Goat1's Avatar
Scott
.035 over 455, stock crank, scat 6.625 rods, SRP pistons, 72 cc e-heads unmilled, ported by a fellow in a wheelchair to flow 325 @ .600 intake, Comp solid roller, 440 lobe, mid-high 270's @ .050, Victor 4500, 1050 Dominator, 91 and 92 jet, 2" Hooker super comps, 3 1/2 pipe to Dr. Gas X and 3" out to Ultra Flo bullets, Manual V body T-400 with ATI 8" treemaster 4400 stall, 12 bolt built with all moser stuff, spool, 4.10 gear. Car weighs 3525 race ready and uses stock suspension and sits real high.
I am going to lower the car, do some more cage work for 9's, and rework the rear suspension over the winter... for the short time I am going to a Mallory comp 250 pump since my comp 140 lost fuel pressure the entire pass when I watched the gauge Saturday...
Faster on nitrous…
Old 07-15-2008, 10:51 AM
scott70's Avatar
You are definetlly knockin' on the 9's,very nice.Do you run pv's with those jets or plugged?
Old 07-19-2008, 06:42 PM
69Goat1's Avatar
Got a really good deal on a Mallory Comp 250 locally and got it installed this afternoon - bolted right up to where my 140 was and only had to change a couple of lines and add the bypass to the cell - seems to be working nicely - May be a while before I can see if it helps though due to this friggin heat
Faster on nitrous…
Old 07-19-2008, 09:13 PM
issach428's Avatar
johnny, everything is running great now and the car pulls way harder than it ever did the entire rpm. Between the horrible rocker clearance issue, way too loose timing chain and 5 degrees retarted and a messed up fuel pump i am hopeing to see some realy low 11's if not hight tens. It ran 11.69 when it was all messed up. Hey i got this converter thats taking up to much space on my shed floor.
