I wanted to know if these are really lowed on the street or are they qieter than some other Mufflers like Flow Master or Hooker? i am looking at PN 17296 3"in and out pollished stainless steel, I have had Borla XR1's on the street and they weren't that bad, Thanks for any comments!
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines! 2006 silvy Z71 4X4,383 LS 600+hp NA Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-} |
I like the sound of the Ultra-Flo's. Quieter at idle and crusing than Flowmasters, but at WOT they are just as loud. I am also running an X pipe. Very little resonance too. If you have Jim Hand's book review his comparisons.
i'm on my second set of 3.5" ultraflows with x pipe in a ten year period.went from 3.5 flowmaster top ten shootout mufflers. ultra flows are quieter and performance picked up at the track. like 4mula71 said no resonance and nice cruising.
Thanks guys! I will be running these, question is either of you running 3.5 dual oval exhaust? curious how to adapt the oval to round muffler
I run the 3" inlet/outlet welded UltraFlows and they have a more mellow sound than 40 series. Also have the X crossover and 2.5" tailpipes. Slight drone around 2000rpm. Not a problem. I've run 11.32@119 through full exhaust with 4000# wagon.
I have 2.5" stainless ultraflows, no x-pipe, on my 64 GTO Tripower. It is louder than I expected but sounds really nice. Has deep rumble, not that tin-canny sound like on some chambered mufflers. Like someone said, a little drone around 2K rpm, but it is ok. I like them and would not change them. Pretty quiet idle but really sound off when i get into the throttle.
64 GTO Tri-Power Convertible, 4-spd 2nd owner, since December 1965 |
Nice, I Really can't stand low flowing F-masters! they are mustang muffs IMO, I also like the Borla XR1 sound but the DM UFlos actually flow more so thats what i will do, FWIW most ex kits are made for offset muffs i wonder how hard to make these fit?
I have a 2.5 inch exhaust with them behing my 400. I wouldn't have anyother muffler. Good sound at idle, not too loud. Cruising you don't have the interior resonance like flowmaster. Wide open they sound great. Mean. IMHO best muffler you can buy for the money. Oh yeah, I did notice a performance gain also. Good Luck.
1969 Firebird "400". 408 Pontiac, #62 heads, 274 XE cam, Eddy RPM intake, Quick Fuel Slayer 750, Carter Super Street fuel pump, Mallory Unilite, Turbo 400 with shift kit, Continental "Jim Hand Special" 3200 stall, 12 bolt 4.10 posi. 1 5/8 inch headers, 2.5 exhaust with Dynomax Ultraflos. |
My TA has the 3" Ultraflows and an X and is quiet, runs as good as open headers.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Anyone have a sound clip or video with there car idling and driving???
Yup I just started my build today with ultr flo's welded Dynomax 22" 2/1/2 -2/1/2 off set off set. Can't remember the part number off hand.
I love them. Check it out! http://s518.photobucket.com/albums/u...t=MOV09560.flv http://s518.photobucket.com/albums/u...MOV09561-1.flv
69 400 Block, .030 over, KRE eagle stroker kt, KRE,CNC ported e-heads 310 cfm, port match RPM , comp roller 236/[email protected] 586/600 lift 110 LS. 1.5 HS roller rockers, 350 Transmission, Red Neck tight 3500 stall converter, Ford 9” with 3.75’s, Strange center section, Moser 31spline axels, 29”Mt slicks, HRPARTSNSTUff anti roll system, Doug’s Headers 3.5” collectors, 22”Dynomax mufflers w/ H-pipe, Cliffs Q-jet, Fuel cell with sumps, Mallory 140 fuel pump and filter. Denny’s 3.5” drive shaft. Last edited by 70 Lemans; 08-11-2008 at 09:42 PM. |
Mine are actually very quiet. Like passenger car quiet, you need to be standing behind the car while idling to hear anything that resembles a rumble. If that gives you an idea of how quiet. Since I am not really a racer and I don't need that extra little bit of air flow, I am ready to put some more restrictive but louder mufflers on my car.
Mitch Kunath |
I have the 2 1/2 race pros on with a 3" X ... same sound and u get them right here from our host!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
I run Dynomax Ultra Flo Stainless Steel 2.5 inch muffs on my ride. I have a 3 inch exhaust up front with the PYPES X pipe so needed a 3 inch to 2.5 inch adaptor set. Sounds great and way quieter than the Flowmaster stuff out there, flows better too according to the flow tests done by the Hand family on their Silent Power CD.
Talk to whomever it is that is supplying the 3.5 inch oval about transition pieces. Are you getting that oval stuff from Dr. Gas or RARE ?
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
I will put my vote in for the Dynomax Super Turbo's. I run them with a 2.5" system with factory Ram Air Exh. manifolds and the sound is excellent. Idle is just right, and when you get on her, she really gets your attention!
Admiration for Ponchos.......... |
I just installed a pair of stainless steel 20" case 3" Ultra-Flo #17547 mufflers in place of a set of race Flowmasters on my street car (ex-race car), pretty happy with the outcome:http://forums.maxperformanceinc.com/...=516251&page=3
I was considering running the Super Turbo mufflers instead, but space constraints wouldn't allow that. I feel my car 'needs' a little more aggressive sound anyway, so I'm really not at all disappointed that the Ultra-Flo mufflers were a better physical fit for my chassis. I do like the Super Turbos, I run the 20" case #17749 2-1/2" pipe versions on a couple of my '64 A-body street cars and really like them.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
I just went with the Ultra-flo's myself. Replaced a set of FM 40's. Thse are a little deeper sounding than the 40's, but still very loud IMO. 3" offset in/out with X and tails. 14" long case (maybe thats why there still loud)
The 14" case is about all that fits under the 2nd-gen F-body cars, not much space for mufflers under there. I went for the 20" ones on my A-bodys to try to tone the sound down as much as possible, for better flow, and of course because the chassis will accept them. |
Thanks for making the clip Bart. Your car sounds nice and mean. I believe it sounds similar to what my Goerlich's would sound like if I were not running a X-pipe.
1967 GTO Tyrol Blue/Blk Cordova 400, TKO-600, 8.2 Posi w/3.55 400 + .020, decked to .005 SD Performance 240+CFM 670 heads RARE HO/RA manifolds RARE 2.5" Exhaust (18" Magnaflows) SD "Stump Puller" HR cam (230/236, 112LSA, 107.5 ICL) PRW stainless 1.52 roller rockers Forged TRW slugs SCAT H-Beam forged rods |
