Old 08-11-2008, 11:30 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Maybe borrow a new gun to make sure but if you're readings are correct you should only need 16 degrees initial and 20 mechanical as a good base ( vacuum unplugged ).
The car should run with 16 degrees unless you set up the idle for the crazy initial timing and the carb screw is out way too far.
Ideally you'd want 36 total and 48 cruise with the vacuum advance on.
Springs can cause a bounce on the gun if they don't seat properly.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
