#661
Old 08-09-2008, 11:02 AM
njsteve's Avatar
njsteve njsteve is offline
I picked up an extra set of 15x7 honeycomb wheels for my BFG radials. (from earlier posts you know I will be using the Polyglas GT's for show). Found these on ebay reasonably cheap and only about 25 miles away.
The problem with these wheels is that the internal steel supporting cone that runs from the mounting flange of the wheel to the center cap mounting point is usually mangled from years of abuse from tire machines, pried off center caps, really high curbs, etc. The normally pentagon shaped flange is commonly trapazoidal from the years of bad treatment. There is no way to access and repair the cone if it is damaged...unless you get creative.
Here is the set and the ovaled out center caps areas:
  #662
Old 08-09-2008, 11:03 AM
njsteve's Avatar
I "thunk" to myself, well what do you use to make a dented tube round again?...and a lightbulb went off. Use a muffler tailpipe expander!
I borrowed my buddy's 30 year-old piece of iron hardware and plunked it in the center hole, gave a few whacks with a dead blow hammer and voila! Perfectly round again. It didn't even hurt the inner center cap mounting lip on the cone. It just moved everything back into place.
and the result:
  #663
Old 08-09-2008, 06:10 PM
TransAmRIP's Avatar
TransAmRIP TransAmRIP is offline
[QUOTE=njsteve;3379080]I "thunk" to myself, well what do you use to make a dented tube round again?...and a lightbulb went off. Use a muffler tailpipe expander!
It doesn't surprise me any Steve, if anyone can find a way to fix, repair or ? it's you. Another great job.
1974 400 4 speed
  #664
Old 08-11-2008, 08:57 AM
tdavidl's Avatar
tdavidl tdavidl is offline
the funny thing is i've never heard of such a tool (who has....except steve) AND how many of us have buddys that have one (excpet steve)....
so steve, how much are you renting that tool for now that everyone with these wheels is going to want to use it ?
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
  #665
Old 08-11-2008, 08:18 PM
njsteve's Avatar
It pays to have old friends that are old-time mechanics (older than me, that is).
Finished the bodywork and paint on the rims over the weekend. It really sucks having to pay $50 a can for OEM brand paint since they are the only ones that make the Honeycomb silver paint in a spray can. I'm sorry but the R&D cost can't be that massive for a paint that comes from an original factory paint code. Ouch! Maybe it has little bitty pieces of real diamonds in it that make it so sparkly...or maybe they're owned by Exxon/Mobil. (Note my sarcasm here)
Anyway, the wheels came out reasonably well. I will be swapping the center caps from my other set when I use the radials, since the NOS center caps cost about $90 apiece now and no one repros them. Bigger ouch!
  #666
Old 08-13-2008, 12:27 PM
70RAlll 70RAlll is offline
Originally Posted by njsteve View Post
This is the place for plastic welding stuff:
http://www.urethanesupply.com/weldercompare.php
I too have used one of the plastic welders with good results. But below is a link to Fusor line of plastic repair products. I usually don't care much for epoxy/resin based plastic repair products,but on the recommendation from a PY's member I tried some. Man oh man does it work great and is it easy to work with. I used it to repair a couple "rips" and a torn mount hole on a set of original front fender flares. The stuff really works well. And with the $6.50 chalk gun adapter, you can buy a 50ml tube all for under $30.00 I have also used their bumper/flexible adhesive product for fan shrouds and other black flexible plastic parts(like the little 1970 one year only pieces that are in the front window corners that are impossible to find in good condition) and it worked great. Just an alternative to the plastic welding systems...
  #667
Old 08-25-2008, 05:30 PM
njsteve's Avatar
Some recent progress on the block sanding front.
It kinda looks like a 1970's van mural in progress. I think I see a shark, and a cloud, and a pteradactyl...
  #668
Old 08-25-2008, 05:38 PM
The Boss's Avatar
The Boss The Boss is offline
I see a lake with mountains in the background. We need more happy trees!
That will be one straight body when they are done Steve!
Rims came out great - there's hope now for the 6 or 8 out of round center ones I have!
And go racin' in the street.
  #669
Old 08-25-2008, 09:12 PM
What is he doing with the masking tape? I can sorta guess, but would like to know for sure. Maybe I need to learn this "trick".
  #670
Old 08-25-2008, 09:34 PM
njsteve's Avatar
That is the way to get the body lines crisp and straight: by putting the masking tape on the body line and sanding up to it. You do that from above the body line and then again from below it.
  #671
Old 08-26-2008, 07:23 AM
Exactly, good practice too. And allows one to keep sanding level down the entire length of the car.
If you look closely at some 'other' re-paints or semi-pro restos on 2nd gens, the mid-door line disappears or becomes uneven. Anyone who's done a 2nd gen will tell you what a challenge that body line is. That line actually starts forward of the front wheel opening by the way, and runs all the way to the rear.
  #672
Old 08-26-2008, 09:15 PM
Hmmm... thanks. I am practicing/teaching myself body and paint work by doing my '88 Mustang this summer. Hoping to be confident enough to do my birds next. I'm learning a lot, but it's also a fairly simple shape with none of the complex surfacing a second gen bird has....
  #673
Old 08-26-2008, 09:48 PM
I ,for one, want to thank you for all of these pictures.I am going to try and do 75% of the work on my 71 that I am starting resto on this next week.Going to try and do all the body work up to the actual paint. And I would never in a million years thought of this tape trick for the body lines. Definately would have messed them up if I hadn't seen your thread.SO yes, I am really thankful for this thread and your pictures...
  #674
Old 08-26-2008, 09:52 PM
njsteve's Avatar
No problemo. Like the old saying goes: I'm from the government and I'm here to help. ;-)
  #675
Old 08-26-2008, 09:56 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
makes my neck sore just looking at that guy sanding in that position...
great pics though, can't wait to see it in paint.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #676
Old 08-26-2008, 10:59 PM
njsteve's Avatar
The bodyshop guys finished blocking the passenger side and are now working on the rear deck lid, spoiler and filler panel.
  #677
Old 08-31-2008, 03:37 PM
TransAmRIP's Avatar
Default Question regarding your steering shaft
Hey Steve, I was looking at one of your pictures (below) and was wondering if you had painted your steering shaft to look like bare steel or did you just clean it and put it back on. It seems some say it should be black and others say it should be bare steel look. When I cleaned mine it had no evidence it was ever black so, I restored it to look like bare steel. My picture shows bare steel after cleaned up and pic after restored. Just curious...
Thanks,
Bub
ID:	141639   Click image for larger version
ID:	141641   Click image for larger version
1974 400 4 speed
  #678
Old 08-31-2008, 10:18 PM
njsteve's Avatar
I just cleaned it up and left it natural metal with a little oil on it to protect it from rust. It never had any paint on it. I have tried my best to keep all the original finishes on the parts that didn't need refinishing. I have been striving to do more of a preservation of existing componentry from the underside and suspension areas, than a restoration. The body and paint, of course, needed the full restoration efforts.
  #679
Old 08-31-2008, 10:28 PM
TransAmRIP's Avatar
Thanks Steve, thats what I needed to know.
Bub
1974 400 4 speed
  #680
Old 09-03-2008, 04:53 PM
njsteve's Avatar
A few progress shots of the rear window filler panel getting massaged into place. It's kind of a tricky piece since it forms the bottom of the rear window channel. It's a big water leaker if you get it wrong. It's also impossible to remove without cracking the rear window glass once the glass is installed.
