Old 08-18-2008, 03:32 PM
Leonard Welch's Avatar
Leonard Welch Leonard Welch is offline
Default What's wrong with this door hinge?
Greetings,
I've noticed an issue with my driver-side lower-door hinge. Here's a picture of the 'good' one on my passenger door:
http://pages.cthome.net/lenbo/DSC06202.JPG
Now here's the one on the driver-side:
http://pages.cthome.net/lenbo/DSC06203.JPG
http://pages.cthome.net/lenbo/DSC06204.JPG
I only recently noticed that the top of the pin looks bent. I have had a problem with the driver door not staying all the way open all the time for a while. Now I'm wondering how to correct this. Would this require a door hinge pin, washer or entire door hinge replacement?
Thanks in advance!
Old 08-18-2008, 04:58 PM
gloryrestoparts's Avatar
gloryrestoparts gloryrestoparts is offline
looks like the bushing is shot and it's started the wear on the detent and roller. depending on what is bad, it could be just a bushing to completely replacing the lower hinge
http://gloryrestoparts.20megsfree.com/
1970.5 Pontiac Tempest GT-37
400ci 4bbl 4sp 3.90:1
12.73 @ 112.42 2011 Pure Stock Drags
12.71 @ 110.58 2013 Martin FAST/FS race
12.70 @ 111.74 2014 Pure Stock Drags
12.60 @ 111.66 2015 Martin FAST/FS race
1968 Pontiac Firebird 400
TH400/3.08 open
export car - factory heater delete
14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags
14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race
Old 08-18-2008, 08:20 PM
Thanks. Is it possible to take off only the lower hinge? And/or is it possible to only remove the pin in question to replace the bushing without removing the whole hinge?
(Sorry for the questions - I've never removed/rebuilt/replaced hinges.)
Old 08-18-2008, 08:33 PM
Yes it's possible to remove only one hinge. you'll need a floor jack to do it tho. A block of wood and a towell to keep from damaging the paint isn't a bad idea either.
Do the hinge in a vise.
Mike
former." --Albert Einstein
- Winston Churchill
Old 08-18-2008, 09:07 PM
wytnyt's Avatar
wytnyt wytnyt is offline
door pin and bushings but if bushings have been bad long enough,,may need hinge
