I may be way off here, but I chased an overheating problem years ago and it ended up being the distributor vacuum advance leaked. This threw off the timing enough to cause the engine to run hot. Good luck! When women are hot,that's good, when your engines hot, that's not.........
Drivin' fast and takin' chances!!!!
I had a similar problem recently, I flushed the cooling system 5 times, then filled it with 70-30 mix (70 percent watter 30 percent A/F) and now I run 15 degrees cooler. SInce I don't have a separate tranny cooler, I put in new lines (the old ones were in bad shape) and slipped and insulator on the lines, they run right by the headers.
By the way I run a Taurus 3.8 fan at low speed with a 180 degree t-stat and a 175 degree fan switch.
Can do the talk, can't do the walk......therefore need deep pockets ![]() Injection is nice but I rather be blown If you got it flaunt it, if not fake it (Snoopy) Original 1977 Firebird / Welded tube frame connectors TH350 with shift kit / 400 bored/stroked to 455 by PDude OCD=Waxing and polishing your oil filter SICK=wetsanding your exhaust pipe |
oh boy!!!!! that is a tuff choice
