Old 09-03-2008, 10:14 PM
I ran a similar combo, I went one size smaller on the cam and used a Q-jet carb:http://forums.maxperformanceinc.com/...1&postcount=22
Old 09-04-2008, 07:17 AM
erikgto's Avatar
erikgto erikgto is offline
If I should get a Qjet, what Qjet should I get then?!?
Anymodels/series that are best suited for this application?
I don't think I need a 800/850 cfm Qjet for this mild combo....
'67 GTO hardtop coupe 400 2bbl (sporting a 4 bbl)
'70 GTO convertible 400/400, matching numbers, Currently getting worked on again, body in the bodyshop, engine at the machine shop etc!!)
'71 LeMans Sport T41 Coupe restomod (GTO clone with Judge stripes and wing) 400/350
'71 LeMans Woody Wagon 400/350 patina project
1975 Grand Am 400 factory sunroof project car
Old 09-04-2008, 08:50 AM
bnorris_74's Avatar
bnorris_74 bnorris_74 is offline
I just put the K2801 in a 72 400 with 7K3 heads and I like it.
I looked at the Comp XE268H but Comp says you cannot run stock springs and must have an adjustable valve train.
Old 09-04-2008, 10:45 AM
Z Code 400 Z Code 400 is offline
The 1977-1979 Olds/Buick Pontiac Q-Jets are great. The linkages can be changed to Pontiac easily when you install new throttle shaft bushings...Robert
Old 09-04-2008, 10:57 AM
440GP69's Avatar
440GP69 440GP69 is offline
800 Q will work great!
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
