Old 09-04-2008, 11:00 AM
altfueler altfueler is offline
Send a message via Yahoo to altfueler
Default NO EXHAUST VALVE SEAL? OK?
I TRADED & HAVE A SET OF 7K3 HEADS I AM ABOUT TO INSTALL ON MY ENGINE. THEY HAVE A FRESH 3 ANGLE VALVE JOB, NEW DUAL SPRINGS, ETC.
THEY HAVE NEW INTAKE VALVE SEALS ( BLACK WITH YELLOW & HAVE THE METAL RING ), YET EXHAUST VALVES HAVE NO SEAL!!!
SOMEONE ALSO MISTAKINGLY INSTALLED THE SMALL FLAT O-RING AS WELL, THE TYPE THAT IS A SECONDARY SEAL FOR STOCK TYPE VALVES WITH THE GROOVE. THESE VALVES HAVE NO GROOVE SO THE O-RING IS USELESS!!!
IS THIS OK TO RUN NO EXHAUST VALVE SEAL? I HAVE SEEN SOME THREADS SUGGESTING THIS......JUST WANT A GOOD OPINION.
I AM THINKING OF REPLACING ALL THE SEALS WITH THE GOOD PIONEER VITON, JUST TO BE SURE.
Old 09-04-2008, 11:36 AM
fasteddy's Avatar
fasteddy fasteddy is offline
I have never run exhaust seals. Just make sure the guides are snug.
fasteddy
Old 09-04-2008, 11:46 AM
SupergasDil's Avatar
Exhaust seals are not required but, I have them installed anyway.
Old 09-04-2008, 01:01 PM
racegto65's Avatar
racegto65 racegto65 is offline
I used to run without exhaust seals on my race motor but started using rubber umbrella seals (OS450) on the exhaust as an extra precaution.
Old 09-04-2008, 06:07 PM
Thought on no exhaust seal-pressure out no suction in like intakes. And with the added heat might need a little extra lube there.
Old 09-05-2008, 10:57 AM
Default Thanks!
Thanks for the input guys! I took your advice & assembled the heads w/o exh. seals.
