#41
I agree, too often these threads take a turn for the worse. But I have always heard that "Misery Loves Company". |
#42
well stated by both scott stoneburg and74SDFormula.BTW,ksgto,I would'nt worry too much about how "big" your cam looks on paper.You've got a real torquer on your hands,and both you and your daughter should have a blast driving it,and at that point,it does'nt matter a hill of beans what the cam numbers are,as long as you're happy with it.Good luck!
#43
Definately, The mustangs and cameros in your neighborhood are going to hate you!, 500+lb feet of torque is no joke, It should run mid to low 12's and easliy drive anywhere !!! Goodluck and Have fun I bet you can't wait to drive it!
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines! 2006 silvy Z71 4X4,383 LS 600+hp NA Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-} |
#44
I'm interested in all the specifics of the build, static compression ratio, head flow numbers, camshaft specs, etc, for comparison purposes. We'd built and dyno'd quite a few 455's, and observed quite a few more up on the dyno. The numbers look like it's in the mid 9 to 1 range for compression ratio, and using a pretty "small" cam. Probably an XE268, but that's just a guess?.....Cliff
#45
1967 GTO Tyrol Blue/Blk Cordova 400, TKO-600, 8.2 Posi w/3.55 400 + .020, decked to .005 SD Performance 240+CFM 670 heads RARE HO/RA manifolds RARE 2.5" Exhaust (18" Magnaflows) SD "Stump Puller" HR cam (230/236, 112LSA, 107.5 ICL) PRW stainless 1.52 roller rockers Forged TRW slugs SCAT H-Beam forged rods |
#46
I just did this procedure, of course it was outlined to me by Keisler Engineering, (great people, products and service by the way) What i did was measure the dist. from the METAL end of the tranny tailhouse to the pinion flange face, I got 56 1/8. Type in Keisler engineering and they have a diagram to do this. Keisler's tech guy Richard @ ext. 201 is THE MAN, he has seen it all and has helped me immensely. He's awesome, I am sure he can answer any ? you have. Good luck.
#47
#48
BTW Dynos only measure torque. HP is a mathematical dirivative or torque over time.
HP=Torque times RPM divided by 5250 So all engines will make the same horsepower as torque at 5250 RPM. The abilty to sustain torque at a higher RPM will generate higher HP levels. IE 10500 RPM the HP will be 2 times torque. Also, V twin Harleys are dominating NHRA Pro Stock MC two valve v twins vs four valve 4 cyl Just because we call it a stroker, the reality is it is just a 455 with 3" mains and 400HP 500TQ out of a stock type 455 is pretty good.
1989 Automotive Hall of Fame Inductee |
#49
1. HP is not torque over time. I can apply 100 lb-ft of torque to a head bolt for a second or an hour, the power is ZERO if it doesn't have any motion. 2. It's not "5250," it's 5252, because 33,000/6.2832=5252 rounded off. 3. 400 HP is pretty good, but a 400 with stock heads and smallish cam makes more. So there goes the "bigger is better" mentality out the window. 4. Who cares what the modified big twins do? You can have 1,000 lb-ft of torque and be slow, or you can have 100 lb-ft of torque and be fast. What's your point? 5. If the following curves were actual dyno curves, which one would you pick to be the best race engine (ultimately run the quickest ET)?
#50
5252/5250 you are splitting hairs three significant digits 5252 rounded off is 5250
TORQUE times RPM which mean revolution per minute which is TIME Your head bolt comparison does not hold because it is static NOT applying a constant torque over time...if you appliied 500 ft lb of torque to the bolt and continued to stretch the bolt over a period of time. That is not a real dyno sheet, it is a simulation. A real dyno does not need head flow or cam spec input just an engine fuel and operator.
#51
All else being equal a 455 is worth at LEAST 3 tenths over a 400 in the REAL world quarter mile. This is from actual testing REAL world experience
#52
![]() So 100 lb-ft of torque times 100 RPM is 10,000 units of time? How does my clock support that idea? Say, do you know what time it is? Sure, it's 10,000 lb-ft-RPM. ![]() Quote:
![]() ![]() By looking at the curves, which one would you say would ultimately be faster?? Last edited by Motor Daddy; 09-28-2008 at 03:19 PM. |
#53
Please, do tell. What were all the specifics of each combo? Don't spare the details. I want to know everything from air temp to traction coefficient to drive-line loss to A/F ratio, to VE%.
#54
Peak numbers mean nothing, you will only be at the HP peak and torque peaks for an instant. The area under the curve, average mean alot more. From real experience all else being equal, the 455 will be quicker than a 400, ALWAYS
#55
Here's my take on the deal. Engine A in second gear (1.98) with a 3.23 rear gear and 26.5" tire. 2000 464 lb-ft 176 hp 24 mph 2967 RWTQ 2500 482 lb-ft 229 hp 30 mph 3082 RWTQ 3000 496 lb-ft 283 hp 37 mph 3172 RWTQ 3500 511 lb-ft 340 hp 43 mph 3268 RWTQ 4000 506 lb-ft 385 hp 49 mph 3236 RWTQ 4500 481 lb-ft 412 hp 55 mph 3076 RWTQ 5000 427 lb-ft 406 hp 61 mph 2730 RWTQ 5500 363 lb-ft 380 hp 67 mph 2321 RWTQ Engine B in second gear (1.98) with a 3.73 rear gear and 26.5" tire. 2309 410 lb-ft 180 hp 24 mph 3028 RWTQ 2887 430 lb-ft 236 hp 30 mph 3175 RWTQ 3464 460 lb-ft 303 hp 37 mph 3397 RWTQ 4041 465 lb-ft 357 hp 43 mph 3434 RWTQ 4619 465 lb-ft 408 hp 49 mph 3434 RWTQ 5196 445 lb-ft 440 hp 55 mph 3286 RWTQ 5773 390 lb-ft 428 hp 61 mph 2880 RWTQ 6351 330 lb-ft 399 hp 67 mph 2437 RWTQ Two identical cars (except for engine and gears, same weight) are moving along at a steady 24 mph in second gear side by side. They both punch it at the same exact time. Which one will pull ahead immediately, and get to 67 mph the soonest, and cover the greatest distance in the same time period? The one with the greatest engine TORQUE, or the one with the greatest engine HP?? BTW, these are the numbers from the curves I posted earlier. Engine A is the 455, Engine B is the 400. |
#56
1 example of many REAL WORLD examples:
Completely stock 1969 Ram Air IV 370HP rated, stock convertor TH400 4.10 gears 13.4xx best over a 3 year period. Afraid of hurting the rare engine installed a completely stock 1971 455HO rated at 335HP 8.4:1 compression vs. 10.75:1, Ram Air III AT cam vs. Ram AIr IV cam. 12.8xx best.
#57
Keep racing your computer and I will race and win in the real world
#58
Your data is so flawed it isn't funny. |
#59
...and rocks will fall to the ground if you lift them up and release them, but that doesn't mean you know the cause of gravity.
#60
DATA???? HARD FACTS, REAL WORLD, 28 years of actually racing a real car
