Old 09-28-2008, 06:37 PM
dragula81's Avatar
dragula81 dragula81 is offline
Question 455 - Which factory heads to use for weekend racer
I have a bunch of heads that I'm about to sell but I want to keep the best set for myself for an upcoming 455 build in a 2nd gen TA. Below is a list of what I have right now. I need the accessory bolt holes.
I intend to build just a streetable, weekend racer on pump gas. I get machine work including port and polish work for free by a local builder so I figured that I'd just use a set of these heads since I already have them rather than going with aftermarket alum heads.
So, which ones out of the list below should I keep for me? I know that a lot of people run the 6X's but I wasn't sure if I might have something else on my list that would be a better choice.
Thanks for any help!
(Note that lines of the same color are matching sets)
Drag
www.dixiemusclecars.com
The Southeast's only online Community dedicated to the American Muscle Car!
2006 PBM GTO LS2
1995 Arctic White Trans Am LT1
1981 Trans Am Daytona Pace Car
1969 Gold Poly Firebird w/400
Old 09-28-2008, 06:54 PM
Ollie's Avatar
Ollie Ollie is offline
Any of the 6X-4 heads # 3, 7, and 12. They will have a 96 to 98cc combustion chamber. On a 455 these will have a pump gas friendly 9.0 to 9.5 cr. These will also have all the correct accessory bolt holes for a 2nd gen TA.
Its ok to giggle and snicker, Dont laugh and point
Old 09-28-2008, 06:57 PM
BVR421's Avatar
BVR421 BVR421 is offline
IMO, They are all pretty equal in stock form or ported either one. Pick the head by combustion chamber size to get you 9-9.5 compression.
If you are going to run them stock or do some home porting, use yours.
If you are going to get a pro porting job done, ask the porter about useing their cores, it may be cheaper to sell all of yours and use their core when you figure shipping costs.
Also consider a used set of well ported factory heads from someone who is upgrading to aluminum race heads. Ive seen some real bargains in the classifieds, like nearly half price on for example 6X/260cfm heads that were originally 12-1300$ from respected porter.
Old 09-29-2008, 06:48 AM
Those #64 would be great if they have the larger 1.77" exh valve already you would be starting off with a better exh port than the 6X without porting, other wise it should be a ported 6X-4 head with out question fitted with the 1.77" exh valve.
Old 09-29-2008, 10:45 AM
OINK 1's Avatar
OINK 1 OINK 1 is offline
1970 #15's: RA3 combustion chambers, 10to1, install screw in studs and drill and tap the end 2 exhaust flanges for headers. YA notice how they're not listed ???
BIG TIME ASS KICKERS.
Pontiac Gregg
Greg Merrick
