Originally Posted by Larry Navarro
so, you ordered and installed a complete system and the tailpipes couldn't be lined up?
Strange.
Yes. Actually it was more convoluted than that
. The system came with the wrong x-pipe setup (the wide one vs. driveshaft tunnel version,) which made it impossible to install anything. We got the correct x-pipe, and the tailpipe just was not going to line up perfect with the offset/offset muffler. We are guessing the tailpipe was not bent 100% correct necessitating the different muffler
. However, if I was not anal about ground clearance, we could have made the offset/offset muffler work. Either way, BSM Exhaust (the vendor) took care of the problem, and I couldn't be happier with the way the system came out
