Old 11-04-2008, 11:35 PM
bonneville Joe's Avatar
bonneville Joe bonneville Joe is offline
I think tanks are about $120 new and the sending units are about the same price. Small price to pay to know your engine is getting clean gas. I know that car has been sitting for along time. I guess your dad must have talked to my friend Dave and mentioned you got a bunch of parts with it also? I'm always looking for stuff if you don't need what you got.
_____________________________
www.classicpontiacrescue.com
Old 11-04-2008, 11:39 PM
Axle07's Avatar
Axle07 Axle07 is offline
lol yeah, of course standing out from the crowd isn't a bad thing By the way, what year trans am and engine do ya have in there
Old 11-04-2008, 11:40 PM
As far as ignition. Does it crank when it dies? Just run a test light to your battery connection on the dist with the ignition on in the run position. If the dist is getting juice I doubt its an ignition problem. Cars need 3 things to run Fuel, Air, and spark. Air is simple, it would be pretty obvious if the top of the carb blocked and check for vacuum leaks. Spark, check what I just mentioned. That leaves fuel which I would bet is the problem. Usually if it's a spark problem it just won't start to begin with. They either get spark or they don't.
Old 11-04-2008, 11:42 PM
Uh, I have 3 now. One is for sale on ebay.
I have a '78 Gold SE 4spd W72
I have a '77 black hardtop W72 auto
The one for sale is a black '78 hardtop with a '67 400 and original 6X heads. It's my daily driver. I wanna sell it so I can keep the '77 I just got.
Old 11-04-2008, 11:46 PM
Axle07's Avatar
Let's see I got two extra front bumpers, two front fenders, another steering wheel, a hood from a '79 I believe and maybe 1 extra grill. Yeah it has been there a while. The tires were dry rotted and the tank leaked some gas out when we got it home (after it sat out for about a week) After we tuned it up a bit it ran good and thats when I ran into that problem. The guy we bought it from said the carb had been loading up so we figured putting a kit in and replacing some old parts would fix it. That made it run even better but same problem still came up. Other than that problem I'm pretty confident in it. It has 2 thrush glasspacks on it but the one on the passengers side has a huge hole in it which is annoying. I'm thinking once I get this problem solved when taxes come back I'm going to have the engine rebuilt and have a bigger cam put it in.
Old 11-04-2008, 11:48 PM
Axle07's Avatar
It will turn over when it dies and it tries to crank, last night we almost killed the battery trying to crank it and get it under the car port
Old 11-05-2008, 12:06 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
When it's cranking and not starting, will it start and run on starting fluid?
If yes, you have a fuel problem.
If no, it's probably ignition.
To stay somewhat on topic, I like the looks of that gauge panel a lot, as well. I hope someone will post up some pictures and information if they spring for a set.
Mike
Old 11-05-2008, 12:14 AM
Axle07's Avatar
I've tried pouring some gas in the carb after it cuts off and still no start so yeah, the gas tank could still stand to be replaced either way
Old 11-05-2008, 12:18 AM
Axle07's Avatar
Sorry for like completely changing the subject by the way lol.
Old 01-14-2009, 12:02 AM
Peti972's Avatar
Peti972 Peti972 is offline
so whatever happened to these? anybody seen em installed yet?
Old 01-18-2009, 02:28 PM
OrigOwner77's Avatar
OrigOwner77 OrigOwner77 is offline
For what it is worth, I picked up a Black leather LeCarra steering wheel (w/the silver spokes). Looks very nice. Will install in spring. The only downside is that the black leather they wrap the wheel in is a lighter (more gray) color than the black used on the factory horn button and foam wheel grip.
It mounts to the stock hub perfectly though, so I'm pleased with the steering wheel.
Now...if someone wants to give me some $$$ for the Covan's gauges.... hehehehe.
EDIT: Judging by where the leather is stitched on the wheel (about 5 o'clock position), I *believe* the LeCarra wheel is what is used on the YearOne Bandit cars.
Like Father, Like Son.
Dad's car: 1977 Trans Am: Original Owner, T/A 6.6 400, modified TH350, Hooker Headers, Flowmasters, Edelbrock Performer Intake, Holley 750 cfm carb, 3.91 rear end
My car: 1980 Trans Am: 1968 400, 1969 #62 heads, TH400, Hedman Headers, Flowmasters, Edelbrock Performer Intake, Holley 750 cfm carb, 3.42 rear end
