#81
On another note- two more possible unique items 1)OPH said on another recent thread that 70 had an odd length yoke on the driveshaft. 2)What about the vented gas cap? 70 only? |
#82
The 1970 gas cap vented (49 state) version is NOT used on any other 2ndgen Firebird.
Neither is the 1970 (eec) California version. |
| The Following User Says Thank You to 2manyT/A'S For This Useful Post: | ||
#83
Anyone have a '70 vented gas cap to sell? I need one for my '70 T/A. Thanks!
#84
With all of our lenghty list of '70 only parts, I don't recall seeing a mention of the '70 only quarter panels. Did I miss that one?
#85
Transamric and CaptCrunch, just a followup to the small sway bar question. The build sheets broke the parts out into 2 digit codes for specific parts. What I had wondered about was do the small bar TAs have the Formula two character codes for what I had assumed were the sway bar portions of the build sheet, #17 "Stab Bar" and my guess for the rear sway bar, box #76 "Rear Control Arm" or did they have the TA codes on the sheet but still got the smaller bars?
#86
I'm not sure it helps. I have sheets for TA's that have 3 different codes in #17, FT--,FD--, & FW--. If box #76 is for the rear sway bars, & I'm not sure it is, I see all the TA's show PC & all the Formulas have --PB. Checking a few '71 Build Sheets doesn't seem to help either. Slight different layout has one box for both bars, #21. Looks like FT--40 for Trans Ams.
#87
I think I found one more thing, maybe two ? from the early built cars. The door sill plate / harness guard is much longer than standard, it extends all the way to the firewall. There is also an E-Brake cable cover where it goes out of the floor board.
#88
and F41 SPC PERF SUSP like I said my car got the big ones.......and with 14" JS Ralleye's anybody know what 092 DECOR TAPE is?? |
#89
My guess is the (outside) door handle decal?
#90
I was kinda thinking that..........
#91
correct blue trunk release button (got one) didn't know about the hood springs/hinges, I have a set outside......wasn't there something with the seat belt retainers in the celing? also maybe this was already mentioned, but 2 belts / side...thick grip stearing wheel
#92
I have seen these longer plates myself. Have a set.. I think they were left over from 69 or wre cross used from other Pontiac models when supplys of teh regular ones were short.. but yes, those were used. really doesn't matter which one you use though.. we are sort of splitting hairs when we start worrying about parts that wil never be seen and have no effect on performance...just my 2c
#93
Don't 70 TA hoods have 2 square holes instead of 4 (71-76) on the underside front section?
Steve 1970 Formula 400 (YS) M40 (67-Castillian Bronze / 215-Deluxe Medium Saddle)
1970 Formula 400 (WT) M20 (67-Castillian Bronze / 213-Deluxe Dark Brown) 1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 201-Standard Medium Bright Blue) 1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 211-Deluxe Medium Bright Blue) *SOLD* Last edited by RAFormulas; 01-15-2009 at 05:04 PM. |
#94
No Steve, other way around. '70-72 hoods had two squarish holes in the bottom, leading edge. '73, or late '72, started the four hole design. Another obvious difference is the round vs. oval hole a bit further back & biased to the drivers side, than the other holes you mentioned. Early hoods have a round hole, the later style have an oval hole.
#95
Steve.... did you just find out one of your Formulas has a later hood?? happened to me a couple years ago. hated it ...really thought,as we all do, that my car was all original only to find the hood had been replaced among other items.. original,usable 70-72 hoods can be hard to find. they have a habbit of rusting around the edges and/or at the mounting points.... good luck... |
#96
Nope, sorry RAIII, but you need to go out & look at your TA or std. FB hoods again, like I just did. The oval &/or round hole I'm referring to is biased to the DRIVERS (left) side of the hood.
#97
Nope... all my hoods are the original hoods.
1970 Formula 400 (WT) M20 (67-Castillian Bronze / 213-Deluxe Dark Brown) 1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 201-Standard Medium Bright Blue) 1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 211-Deluxe Medium Bright Blue) *SOLD* |
#98
well I seem to be quite proficient at ramming my foot into my big mouth..and apparently I have done it again.. yes, my 3 early hoods all have the round hole on the drivers side, you were correct and i was wrong...
#99
No harm.......no foul!! You did get me wondering though. Had to go out & check mine before I reposted. At 57 Y.O., could be brain fade!
#100
a few years younger, but the same here.. plus it is 18 degrees here and i am sure some are laughing at me for whining about 18... but here in the south...that was one cold walk out to the shop....we are used to 50 degree Januarys.....
