Any Help out there I'm getting closer to finishing my 3 year restoration project on my 66 convertible and I'm trying to wire the dash back in I have a new harness with correct colors but I dont know what color wires go on the Tach also does the blinker light have a seperate connection? any input on any of the dash wiring would be a big help Thanks Tom
Tach will be a single brown lead.
The Signal is fead by two leads, DK & Lt Blue. What harness are you using? PITA painless or an M&H plug & play?
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car.
Thanks I'll try that I'm not sure what brand I got it from Ames
I am looking at my dash I have a new harness from Ames a M&H and I am wondering if you had all of the light sockets full I don't have one for the BRAKE lamp. I have rallly Gauges also.
Jon |
Brake warning light was an option for 66'.
The factory put the hole & red lens in but you had to pay around $3 for the light itself.
Jeff Is it something I can add on or not?
Jon |
I assume you have the intire 984702 option assembly so the brown lead plugs into the lower right of the fuse box and the black lead goes to the plunger (switch) mounted at the hand brake
There is a kit on ebay right now check this item # 130269360152 this what I have in my car and no I'm not the seller I just seen it there
