Old 11-26-2008, 09:36 PM
Default How loose??
Originally Posted by elevatorman51 View Post
I just checked mine out it reads 07 17 f and A429310 didnt have any failure but it did seem loose on the crank and was around 4thous. larger than the Powerbond. How loose is too loose?
Interesting comment on Scats website under crank snout failure. note comment regarding viscous or rattle type balancers. http://www.scatcrankshafts.com/PDFs/ScatCrank07.pdf
page 55. Also somewhere when I was researching which crank and which damper and which cam timing gear, I was shopping for, I ran across a note to avoid 9 key timing gear as it wasnt good for crank life. I wish I would have saved the link. Maybe it was Cloyes site???? If I stumble on it I'll post it
How loose? I have seen evidence that an interference fit is better than loose. Both in writings of others and personal observations(wear spots that werent there when assembled and crank bolt still tight on tear down). Most Pontiacs are loose fit, but high rpm we can survive these days suggests we change our ways and stop relying soley on 160 ft lbs to keep it from dancing. If loose fit it "has" to be affected by harmonics and vibration. Engines without tightly doweled main caps walk all over even with high clamp loads.
Old 11-26-2008, 10:03 PM
440GP69's Avatar
440GP69 440GP69 is offline
http://www.atiperformanceproducts.co...pers/index.htm Hmmmm, Seams it played into the other Damper Companies hand nicely
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
