| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
update.
i finally got my assembly and i rebuilt my motor. a little piston slap when cold but i can live with that i guess. the motor is in. now im waiting on my 700R4 transmission. yep. i decided to swap out the 6 speed for an automatic. it should be here on wednesday. hopefully i can have it installed this weekend. im dying to see how the 462 spools up that turbo.
Vic in SoCal. Follow me on Instagram- Cloud9orbust 66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi. ![]() My T56 Install My Turbo Build My Vortech Supercharger Build Hyd Throw out bearing Misc Build Pics May the Karma Gods meet you half way.... |
How tall is the carb " hat " and where did you get it from? I need one about 2.5-3 inches tall.
here is one for sale on ebay.... from base to top its looks to be just under 2 inches...
i am no way affiliated or have an interest with the ebay seller...just posting because that is the exact one im running. http://cgi.ebay.com/ebaymotors/Proch...QQcmdZViewItem
Quote by 6D6GOAT: "...yep. i decided to swap out the 6 speed for an automatic."
Definately a smart move with the turbo!
"Objects in mirror are closer than they appear"
How's this coming along?
Curious what this foot brake stalls at and what the advertised stall was? I just snagged a nice set of 64 D port exh manifolds, getting closer to my build thanks to seeing this thread.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
well actually i took it out for its maiden voyage yesterday. i was real concerned with burning up my new 700R4 so i took it pretty easy. i think there might not be enough tension off idle on the TV cable. when i adjusted it i basically adjusted it at WOT. so im going to have to tinker with that. im also getting the fuel injection dialed in. it needed alot more fuel in gear at idle than i did before with the manual (obviously) especially with the low stall speed of the convertor. I also need to rebleed the brakes. the pedal is way too soft for me. im thinking i have some air trapped in the line lock.
but i did get on it once...i just couldnt resist. i manually shifted it. from a rolling start i put er down, she took off as expected, i slap it into second...got a nice chirp then WAAAAAAAAAAHHHHHh the boost came and the tires broke lose...my eyes lit up, i quickly countersteered to keep her straight... it actually kind of scared the crap out of me (in a good way) so i quickly backed off and shifted into 3rd and then checked my pants. the data log showed 8.5 pounds of boost. also alot of smoke at WOT. im hoping its simply that the rings arent seated...i doesnt really have that much time running but seems i have read that moly rings seat quickly. we will see. next its re bleed the brakes...re adjust the TV cable..a couple tweeks to the fuel map. i do plan on getting some video of it.
. Hope that smoke at WOT under boost is not the case in this instance .
Panos Little Miss G Racing on Youtube |
