Old 12-31-2008, 08:44 PM
Pontiacman469 Pontiacman469 is offline
Default What would you do?
So i have these pics from my stuff:Block i bought used,Guy told me he broke a piston and got a new block.I took it to the machine shop about 3 years ago and had "everything"done to it.I'm hoping to have everything together this spring and running.#1What do you think of the main cap?#2Would you run this head?#3Why was there a "M"Stamped on my main block?#4How do i get those lifter restrictors out(Stripped)?Thanks Guys
ID:	153045   Click image for larger version
ID:	153046   Click image for larger version
ID:	153047   Click image for larger version
ID:	153048   Click image for larger version
Old 12-31-2008, 10:19 PM
Thomasmoto's Avatar
Thomasmoto Thomasmoto is offline
I wouldn't use either. I know that's not what you want to hear, but I wouldn't want to put the time and money in them just to worry about them down the road.
Old 01-01-2009, 04:50 PM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
Get another core. They aren't hard to find.
Old 01-01-2009, 10:43 PM
PaulatFast PaulatFast is offline
Should have posted this when scrap was up! Seriously, I would not even run that block if it was original to my Judge, nor the head. As was already stated, cores are still cheap. Good luck.
Paul
FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first.
My site... needs updated-
www.fastrestorations.com
68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs!
Old 01-02-2009, 11:30 AM
OINK 1's Avatar
OINK 1 OINK 1 is offline
Thumbs up Checking block/Pontiac Gregg
I have done over 800 Pontiac motors, it's not to bragg, it's so you know the data is good.
Please call me and I will help you .
Colorado
1-303-776-0877
Pontiac Gregg
Greg Merrick
Old 01-02-2009, 12:25 PM
Colorado
1-303-776-0877
Pontiac Gregg
We would all benefit from your thoughts on this, why not share?
Paul
Old 01-02-2009, 02:54 PM
Schurkey Schurkey is offline
Anything "can" be fixed; the question is whether it's worth the time, money, effort, and enthusiasm.
I don't like what I see in the photos; and I wouldn't use those parts as my first choice. On the other hand, the welded areas are not in heavily-stressed areas of the block. And the restrictors are a drill-bit away from being gone--or--effectively gone.
In particular, after having a "Learning Experience" with some Oldsmobile heads, I am now at the point where I have a very hard time justifying repair to OEM head castings; it's worth some extra money to me to scrap 'em and start fresh with aftermarket aluminum heads. I got lucky, my Olds heads did end up being usable and water-tight--but--it could easily have gone the other way. So now I have 1/2 the cost of aluminum heads invested in compromised castings--and--the front of the car is too damn heavy anyway. What was I thinking?
